Views on royal purple oil
Old May 14, 2006 | 10:07 AM
virgils4.85spd's Avatar
Default Views on royal purple oil
Im gonna try a royal purple oil change. Anybody else doin this? Did it help your mileage? Is it worth the money?
Thanks,
Derek
Old May 14, 2006 | 10:09 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
It's a good quality synthetic. I don't know if it's any better than M1 or any other synth.
I run M1 and I think I get better mph for it. Certainly it's better for cold starts and abusive behaivior
Old May 14, 2006 | 11:09 AM
Colby 04's Avatar
horsepower tv did a complete fluid change on a camaro and a dodge truck one time....they dyno'd them before and after. The results weren't worth the additional costs.....it was less than 10HP, I think, on both vehicles. They did engine, tranny, transfer case, and rear diff's. If you're just doing the engine, you won't get you any noticeable mpg improvement.
Old May 14, 2006 | 11:46 AM
Neverdone's Avatar
June 2006 Sport Truck (page 90) did a conventional oil dyno pull, then dropped all fluids and replaced with royal purple and then did another dyno pull which netted a 10 HP gain. Dyno pullls were 30 minutes appart.
Old May 14, 2006 | 11:48 AM
MON-E-pIT's Avatar
royal purple is good, but costs too much. AMSOIL is the way to go
Old May 14, 2006 | 11:55 AM
Quik's Avatar
5 year bitches!
heres my thoughts.
15.1 with 35xx miles with K&N filter/flowmaster muffler DINO oil
14.6 with 15,xxx miles with K&N filter/flowmaster muffler with royal purple oil. same basic temp out side and track conditions.
biggest difference i seen was the mileage and the mileage was all with syn oil. no other mods were done. yes i know motor did break in but i used syn the whole time. i noticed the truck was better over all and quieter then other trucks that were similar.
ive used it for 45k miles in the 5.3 i used to have, no it didnt fail i pulled it to be replaced with my LQ9. right at the moment i run dino oil but will go back to royal as soon as i get break in miles on it again
Old May 14, 2006 | 12:25 PM
shandy294's Avatar
How much is RP a quart? I use M1 and it's about $4 to $6 a qt here.
I don't know if I got any mpg or hp gains from it. It lubes better and keeps the engine cleaner...that's good enough for me.
Old May 14, 2006 | 12:43 PM
Default I paid ...
6.50 per quart at oreilley.
Derek
Old May 14, 2006 | 12:52 PM
Colby 04's Avatar
Originally Posted by Quik
heres my thoughts.
so you used conventional oil at 35K miles and the royal purple at 15K miles?
Old May 14, 2006 | 01:01 PM
Quik's Avatar
5 year bitches!
no 35xx is 3,5xx miles like in 3500 miles
truck has had full syn in it since the first oil change. at 3,5xx i still had the factory oil in it
get it now?
with what i described and Efans i was getting 20mpg with a/c on and typcial daily driving. in PGH,PA
