Valvetrain noise after TSP 220R swap
Hey guys,
Did a cam/head swap on my truck. 2003 Silverado 2500. LQ4 with a few miles (213k) but, no piston slap, no oil useage and spotless clean inside, so should last untill I build the replacment for boost. I went with a TSP 220R cam with a 114 LSA and a set of ported 4k mile 243's with Comp 918's. and 4k mile stock rockers. New GM oil pump with a shim. 72psi at cruise and 40psi at hot idle. Lifter preload is maybe a bit tight at 3/4 turn on the intake and exhaust, but should be ok. Truck makes great power and runs nice with a notable lope at idle. Valves sound ok at idle but anything 1200 and up make a fair amount of noise, some floaty ticks and some more rythmic ticks. Just not sure how much noise to expect with this cam profile?
Thanks in advance for any input
-Ryan
-Ryan
Hey guys,
-Ryan
-Ryan
Explain this... Did you take the slack out of the rocker, then tighten it down with a torque wrench and get 3/4 of a turn from the rocker bolt to get 22ft-lbs? If so, you need a longer pushrod.
So there is exactly 3/4 turn preload on the lifter.
Increased valve train noise is par for the course with an aftermarket cam and springs, but since you did heads also, it would really be a good idea to check lifter preload the correct way, with a pushrod length checker. The turn method isn't always accurate and I've noticed that a lot of folks who do it that way end up with problems and eventually get a pr length checker and end up needing a different length pushrod. There's a sticky in the internal engine mod section about "lifter preload" that is a good read
So the question is, what is the optimum or proper preload!?
superchomper2003
Aug 26, 2015 09:39 AM
