Valvetrain noise after cam swap
Old Apr 30, 2020 | 08:42 PM
Truck2007's Avatar
Default Valvetrain noise after cam swap
New to this forum. Ï recently installed a new LSXceleration cam, 206/212 .515/.522 HR112+2, and i now have valvetrain noise. I used the factory springs, which were still in spec. as they were tested by the company that refreshed the heads. Installed new LS7 lifters. Ï installed with the factory 7.385" PR and had valvetrain noise. I then checked pushrod length at 7.257 zero lash. Ï installed 7.325" pushrods and I still have the noise once it is warmed up. Any thoughts on what to try next? I have also re-torqued the exhaust manifolds after about 3 warm up cycles.
Old Apr 30, 2020 | 09:32 PM
FFDP's Avatar
Got a video?
Some new lifters are pretty noisy.
Old Apr 30, 2020 | 10:07 PM
Truck2007's Avatar
Ï can try to get one tomorrow. Ï recently heard that aftermarket lifters and cams can make some noise but it is just a mild cam.
Old Apr 30, 2020 | 10:48 PM
68Formula's Avatar
When you say factory valve springs, are you talking about the original truck springs, or do you mean the LS3 springs? I think the truck springs are limited to .500" lift, while the LS3 potentially go up to .570" lift before bind (although lift rate and rpm can play a factor).
Is the noise at idle?
Old May 1, 2020 | 07:45 AM
madmann26's Avatar
If it's sewing machine noise, it's because of PR length.
Old May 1, 2020 | 08:23 AM
Truck2007's Avatar
I was assured by LSXceleration and Blackbear tuning that the factory truck springs are good up to .550 lift. Ï agree that the only viable cause of the noise could be PR length, but I checked PR length on 10 different valves and they were between 7.256" to 7.258" @ zero lash. I went with the 7.325" rods because that put me around .070" preload on lifters. With that preload, it took 1.125 turns on the rocker arm nut to reach 22 ft/lbs. The only noise at idle is heard under the truck and sounds like it is coming from the valley.
Old May 1, 2020 | 09:38 AM
Jonblarc7's Avatar
what year truck?
Old May 1, 2020 | 10:59 AM
Truck2007's Avatar
2007 classic ccsb 5.3 L59
Old May 1, 2020 | 11:15 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Your math is wrong. Myself, I run them between 3/4 and 1 full turn.
1 full turn is about .079 preload
Your probably closer to .100 Preload.
Old May 1, 2020 | 11:49 AM
Truck2007's Avatar
Ï went back through my notes and found that my new 7.325" - 7.257= .068" should be 3/4 turn. Ï will recheck today. Either way, the 7.325" rods gave my lifters .068" preload "on paper".
