valve springs
Old Jan 23, 2012 | 09:55 PM
84drgin's Avatar
Default valve springs
Just wanting to know what springs are going to last the longest best bang for the buck.
Pac or 918 or what ever
Old Jan 23, 2012 | 10:38 PM
2000chevysilverado's Avatar
This is something that shouldn't be skimped on patriot dual gold springs are the best out there imo
Old Jan 23, 2012 | 10:55 PM
grey matter 04's Avatar
13 Second Truck Club
depends really
How much lift? Aggressive lobe?
If you can get away using a ls6 spring that will out last them all..Gm designed to run many miles in a corvette
Old Jan 24, 2012 | 07:19 AM
84drgin's Avatar
its on a xer 228/232 588-595
Old Jan 24, 2012 | 08:14 AM
mcfarlnd's Avatar
Un-Registered User
Originally Posted by grey matter 04
depends really
I have replaced a ZO6 engine (bone stock) because of a broken valve spring and I had to change my springs and get a head job because of one (got lucky and the spring coiled together keeping the valve stuck just above the piston)......... So, IMHO stay away from LS6 springs. Get some dual springs and be done with it.
Old Jan 24, 2012 | 10:55 AM
do a search of all the valve spring you can name the ls6 has had way less failures.
Patriots and comp918s i have seen break
Old Jan 24, 2012 | 02:23 PM
2006bowtie's Avatar
for the money id say ls6. i bought a set yesterday, theyll be here tomorrow. good to .570 lift is what they said though.... that might be a little weak for your cam. they only cost $70 though. my cams only .518/.520 round abouts.
Old Jan 24, 2012 | 05:05 PM
01silvy's Avatar
Witht the lift on his cam i wouldn't run the LS6 springs.. the lift of your cam would be pushing the LS6 springs.. I would go for springs with a .650" lift so your not pushing them to the limit and that would help longevity.. Valve springs are like most other engine parts, they are a wear item and should be replaced at certain intervals.
Old Jan 24, 2012 | 06:22 PM
84drgin's Avatar
I think the pac springs 1518 are good anyone disagree
jtphelps289
Sep 29, 2015 12:00 PM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
LT-1 SS
Sep 3, 2015 10:24 AM
mr03silverado
Sep 2, 2015 11:43 PM
