Valve spring/injector question
Old Sep 11, 2008 | 01:52 PM
2 tone 02's Avatar
Default Valve spring/injector question
Ok, I'm picking up a xer273hr for my 5.3l
specs: 224/230 581/588 114+2
I was going to go with the new style 918s, but have still read some bad things about these. What other options are out there for .600 lift cams that work with stock retainers and locks?
Will I need to upgrade my injectors or fuel pump with this cam and my mods: Longtubes, ORY, 3" muffler dumped, elec. cutout, TBTC, built 4l60e, 3.73s, cai, p&p tb, elec. fans, underdrive pulley, 180 thermostat, blackbear tune, etc. I'm also adding a HSW dry shot to it after I put in a tru trac!
Old Sep 11, 2008 | 02:20 PM
00ChevyScott's Avatar
Wearin' da big hat
you're going to need a huge stall for that cam man. thats way too big unless you're going to use that for track only with a 4000+ converter.
Old Sep 11, 2008 | 03:56 PM
sickREDsierra's Avatar
hell, it might hook better with that small converter he has, then once it starts pulling good at 3500 rpm, he will already be hooked up.
Old Sep 11, 2008 | 04:07 PM
aksz71's Avatar
3000,3200 stall is big enough for that cam
Old Sep 11, 2008 | 05:55 PM
2 tone 02's Avatar
From the reading I've done about 3k-3400 is what I'm probably going to do. I'm either sending the tbtc to Circle D to get built or just sell this one and buy one new.
Old Sep 11, 2008 | 10:58 PM
Wearin' da big hat
on a 224/230 cam on a 5.3 with 3.73 gears? Idk about that. My cam is just a 216/220 114 and I need at least a 3000 converter to really take advantage of my cam.
Old Sep 11, 2008 | 11:27 PM
southern_chevy's Avatar
my little 221 cam picks up well a little under 3k
Old Sep 11, 2008 | 11:28 PM
Mangled03gmc's Avatar
Baltimore Whore
Yah to take advantage, but he can get away with a smaller one, just will be a bit slugish from the gate.... I would run atleast a 3k verter thowe, I want a bigger one now, I am rocking a SST3200.....
John
Old Sep 12, 2008 | 12:57 AM
2 tone 02's Avatar
So what about valve springs? Which ones are ya'll running? I'm thinking about the new 918s as I dont want to have to buy new retainers and locks.
GXPJAY
Feb 13, 2022 08:15 AM
The_W
Oct 28, 2015 09:00 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
