V6 to V8 Swap
Old Apr 19, 2007 | 07:36 PM
TchargedLS1TA's Avatar
Default V6 to V8 Swap
NBS 4.3L to 6.0L swap, I know its been beat to death, but I cant find a thread with info about motor mounts. Which ones are to be used? Also which transmission mount must be used. The V6 mount is too far to the right to line up properly.
Old Apr 19, 2007 | 07:39 PM
nightrunner's Avatar
Mr. Obvious
https://www.performancetrucks.net/fo...d.php?t=378643
here is a great write-up by dlh2006
Old Apr 19, 2007 | 07:54 PM
Much appreciated..
I must be the only one with this transmission mount problem..
Old Apr 20, 2007 | 07:46 AM
454SuperSport's Avatar
not sure about the tranny mount. we did the swap in a 2000 and all we changed were the motor mount brackets. give me more info.
Old Apr 20, 2007 | 12:38 PM
Dirty 30's Avatar
LS1Tech Whore
I did the swap in my 03 silverado, what do u wanna know? 8)
Old Apr 20, 2007 | 07:21 PM
Derek @ EDO's Avatar
FormerVendor
the tranny mount does not have to be changed.
Old Apr 27, 2007 | 06:10 PM
OK, I cannot find a motor mount stand to fit on the driver's side. The bolt holes in the frame are about 2-3/4" apart between centerlines. I have about 3 sets of mounts, all from 1500 5.3 engines, none of them work on the drivers side.
What are you guys using for the driver's side? Out of what year/model/engine trucks?
Old Apr 29, 2007 | 02:13 PM
ok, are you talking about the actual motor mount that bolts to the block, or the bracket that bolts to the frame? get the brackets from a truck like yours I.E.( if yours is a 2000 silverado 1500 2wd, get the v8 brackets from a 2000 silverado 1500 2wd).
Old Apr 30, 2007 | 01:29 PM
Im talking about the mounts that bolt to the frame, which are called the stands.. Its for a 99. The mounts I have came from an 02, but I dont see how much different a 99 can be from an 02
Old May 1, 2007 | 12:08 PM
OK, Im convinced this method will not work in a 99 chassis. I have just about every motor mount ever made for this generation truck and none of them work. Might want to put that in DHL's post
