Update on lifter noise!!!!!
Old Jun 21, 2009 | 05:35 PM
  #31
Truckshop's Avatar
coil bind. you will not hit a valve with a piston hard enough to bend a pushrod/break a rocker and not bend the valve. they either put the wrong valvesprings on or the cam has more lift than the springs can handle.
Old Jun 21, 2009 | 09:36 PM
  #32
schino's Avatar
Originally Posted by FireMedic331
I don't think there was any shims, but im going up there in about an hour to do some more work.
Here is what the springs look like that are in the truck. This is the one that came off when the rocker arm broke.
FYI i have some pac 1518's sitting next to me and the ones in your pictures are not them. same shape but the pac spring has one less coil and no paint
id put coil bind as suspect. if a valve hit a piston you would know it cuz the truck would run like **** from a bent valve
hope that helps.
Old Jun 25, 2009 | 01:28 AM
  #33
A Low Dime's Avatar
13 Second Truck Club
Whats the latest on this?
Old Jun 25, 2009 | 04:49 PM
  #34
cej123073's Avatar
i definitely agree i have never seen a valve smack a piston and not bend!!!!
Old Jun 25, 2009 | 05:19 PM
  #35
why did you pay a shop? after reading this thread looks like you have some mechanic skills.
Old Jun 25, 2009 | 05:38 PM
  #36
mred's Avatar
my thoughts exactly
Old Jul 26, 2009 | 11:14 PM
  #37
Badboy464's Avatar
heres what the comp 918s (can handle .625 lift) look like compared to the stockers. those dont look like they can handle .650 lift they look like the stock ones
Old Jul 27, 2009 | 08:16 AM
  #38
KySilverado's Avatar
x2 or 3 on coil bind. Those springs are not high lift capable.
Old Jul 28, 2009 | 12:31 AM
  #39
ahartz28's Avatar
x4 here on coil bind !!
JordanH
Nov 6, 2015 07:42 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
