UPD intake dyno results
Old Apr 24, 2003 | 09:32 AM
Default Re: UPD intake dyno results
If you take out your lower airbox you will see the bigger hole is a separate peice that you can take a flat tip to and push out easy. The main thing I think helped was that the holes only allow so much CFM to get in and it's not enough...pushing out this peice out leaves no restriction to getting the needed air. There's no way for you to have a water problem by pushing it out.
Dyno runs here at Raging Motorsports usually run $55 for a baseline(3 pulls)
GXPJAY
Feb 13, 2022 08:15 AM
lsxperformance
Apr 20, 2016 12:17 AM
AHelm3
Apr 8, 2016 07:51 AM
dselby25
Aug 24, 2015 07:26 PM
bigsapper
Jul 28, 2015 12:56 AM
