underdrive pulleys
Old Feb 1, 2009 | 02:05 AM
454navyss's Avatar
Default underdrive pulleys
are they worth the money? i was looking around at some and found a set that seems like a good deal if doing them is going to be worth my time and money.
http://www.troyerperformance.com/cgi...talogno=549984
Old Feb 1, 2009 | 02:38 AM
Not if you have a stereo.
Old Feb 1, 2009 | 09:18 AM
hirdlej's Avatar
Personally I think they're a waste of money. Some guys will try to tell you they did back to back runs before and after the pulley swap and gained 6-10RWHP. The reality is that this is more than likely due to the fact their engines cooled off while swapping pulleys or the inconsistency of the dyno itself.
Old Feb 1, 2009 | 09:22 AM
nighthawk08's Avatar
great mod. 5-10 rwtq throught the RPM range, better mileage and more HP. can't go wrong.
Old Feb 1, 2009 | 12:40 PM
blackbeast ss's Avatar
i gained 2 tenths in the 1/4 mile with my ASP pulley and i noticed a difference. . . .IMO every little hp/tq adds up in the long run
Old Feb 1, 2009 | 01:02 PM
CaptCameltoe's Avatar
The 3 piece set made a big seat of the pants difference in my 1995 V8 Dakota, as much as my MP R/T cam did, no kiddin.
Old Feb 1, 2009 | 01:17 PM
Ryan02SS's Avatar
I ran an ASP on my SS. I've seen 5-7rwhp gains and the main benefit is the motor revs up noticeably faster.
Old Feb 1, 2009 | 01:18 PM
454navyss's Avatar
not if you have a 2000+ watt stereo.
maybe i will buy it and do it when i do a cam and heads....
Old Feb 1, 2009 | 05:18 PM
skipperdaddy's Avatar
Had march underdive pullies on my camaro back in the day.. same thing... gained an honest two tenths in the 1/4... i like pullies myself...plan in getting the asps...
Old Feb 1, 2009 | 07:39 PM
SSlow 4.8's Avatar
well i may try these...
this particular set is cheaper than summit's sets for our trucks.. however, the gator belts on summit are cheaper... 4 dollars cheaper on summit than that site and im thinking the $35 for the shorter a/c belt must be a typo bc on summit its over $20 different in price. So buy the belts from summit if you do this kit from troyer
How much are the asp's from someone other than summit or jegs?
