underdrive pulleys
HEY!
WHAT ABOUT ME? haha jfwy. so whats the differences between getting an overdrive or underdrive alternator pulley? advantages or disadvantages. wouldnt the overdrive pulley cause the alternator to spin slower, and wouldnt that be BAD if i had a system? wouldnt that be bad regardless. help me out!
The underdrive pulley will be for the crank pulley. Installing it by itself will cause the alternator to spin slower...equals lower output....dim lights.....possible low battery. Installing an overdrive alternator pulley will cause the alternator to spin as fast (or about) as stock with U/D crank pulley....equals normal operation assuming no e-fans or monster sound system.
If you have one or both of those upgrades then you might also look at a 145amp alternator. I had the U/D crank & O/D alt. pulley with 130 amp alternator and got slightly dimmed lights when the e-fans came on.
Spinning the alternator faster or slower won't hurt it or electrical system since it has a built in voltage regulator on the output.
Originally Posted by xsports33
You're comparing two completely different things. What are you looking to accomplish? Future mods?
Future mods: Corvette Servo (if not a completely race ready built tranny), Cam springs and hardened pushrods, Underdrive pulleys, 3.90 gears, exc. I'll probably own this truck till my 2 year old is old enough and responcable enough to drive it. So I have plenty of time to make it faster. just need to know what the best options for the money are.
Vortec350ss
Jan 12, 2016 10:36 PM
