underdrive pulley?
Old Aug 13, 2007 | 11:34 AM
Ferocity02's Avatar
Yes, you will notice that the engine rev's MUCH faster in neutral, especially with the pulley and the clutch fan gone.
Old Aug 13, 2007 | 11:53 AM
TXARKITEKT's Avatar
Yeah, ASP is what I have and love them. I did both pulleys (crank and alt.) and noticed a good performance gain. After I installed them I went out and did a WOT run...I was at 25 mph and stomped it--it kicked down to 1st and I smoked them all the way through and got a 15' scratch at the 2nd gear shift. Before the pulleys, it only chirped on a 2-1 kick down. I got them from rpmoutlet and got a decent price and a good ship time. I say do both for better performance...
Old Aug 13, 2007 | 11:58 AM
abbo7's Avatar
I did the ASP crank pulley and the LS1 fans and I noticed a big difference in acceleration from idle, especially in the summer. The engine feels much more responsive also. Beside that, I also gained about 2 MPG with the E-fans and pulley.
Old Aug 13, 2007 | 02:02 PM
multmigs's Avatar
Anyway with the 6HI conversion at idle
What is this refering to?
Old Aug 13, 2007 | 02:03 PM
multmigs's Avatar
Anyone know the ASP part number to just the alt overdrive pulley?
Old Aug 13, 2007 | 02:32 PM
TXARKITEKT's Avatar
6HI refers to using all 6 lights at the same time---2 fogs+2 low beams+2 high beams=6HI. That draws a lot of amperage off the alternator to run all 6 lights at once...But BlownHD does have the 160 amp alt though...running a 6HI on the standard 105 amp alt on the 1/2 ton might not cut it...
ASP alt pulley part no: 49-540084
Old Aug 14, 2007 | 10:39 PM
Thechevyman122's Avatar
Are the pulleys a pretty straight forward and easy installation....I just did electric fans, and am definately checking these asp pulleys out...both overdrive and the alternator. more info would be great thanks.
Old Aug 15, 2007 | 12:53 AM
BlackGMC's Avatar
Resident Retard
I would also like to know if it affected anyones AC? Does your AC still cool like it did before the pulley??
Old Aug 15, 2007 | 12:59 AM
ONLYA4.8L's Avatar
Werd.. I did oth fans and pulley..Great mods!!!
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
