ummm...where does this go? :confused:
Old Dec 18, 2006 | 06:59 PM
Default ummm...where does this go? :confused:
well after the head swap i was left over with this unconnected, 2 pronged female connector. when i fired it up i didnt throw any codes SO, is it unused?
Old Dec 18, 2006 | 07:11 PM
Rhino79's Avatar
9 Second Club
Map Sensor at the top of the intake on the rear?
EDIT: Knock sensor harness.
Old Dec 18, 2006 | 07:13 PM
Derek @ EDO's Avatar
FormerVendor
i believe that would be the knock sensor harness connector, should have thrown a code or it will.
Old Dec 18, 2006 | 07:16 PM
ogkevin13's Avatar
Banned
just checked my truck couldnt get to much info (2 dam cold) its a 2 wire plug(knock sen.) that runs behind the block. check their for n e unpluged ones? and it goes cliped on the plate that sits on top of the manifold close to the fire wall (by where u bolt down the engine cover)
Old Dec 18, 2006 | 07:53 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Knock sensor plug and you need to go back to Elementary school and leanr basic anatomy, thats a MALE plug
Old Dec 18, 2006 | 08:11 PM
shut up. ...well i looked around and couldnt see anything. someone take a picture of it please please dont tell me i have to take off the intake. PLUS who needs a knock sensor...
Old Dec 18, 2006 | 08:18 PM
1slow01Z71's Avatar
Reach around the back of the intake under it above the valley cover and feel for the plug, you may end up having to take the intake off ot get it.
Old Dec 18, 2006 | 08:39 PM
SnakeOiler's Avatar
It may be a male connector, but it has female terminals
Old Dec 18, 2006 | 09:06 PM
what exactly are the consequences of having it disconnected? i already have my knock sensor sensitivity turned essentially off
Old Dec 18, 2006 | 09:12 PM
Rhino79's Avatar
9 Second Club
They won't report any knock activity to the PCM so you will have no saftey blanket, which it sounds like you don't already.
