Twin alt setup in progress, pics
Old Feb 14, 2006 | 03:53 AM
  #41
dkubricht's Avatar
sweet
Old Feb 14, 2006 | 04:03 AM
  #42
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What do you mean by L terminal wire. Are the wires labeled on the connectors? I dont think mine are. How much length did the dual setup add to your belt?
Old Feb 14, 2006 | 04:06 AM
  #43
TurboGibbs's Avatar
Post #36 dip ****.
stock Radix belts are in the 114" and smaller range. I'd say 4-6 inches longer.
Old Feb 14, 2006 | 04:13 AM
  #44
1slow01Z71's Avatar
Originally Posted by mjhoward
Post #36 dip ****.
That is for a truck with a radix dipshit
Im going to bed maybe someone with some useful will post up by the time I wake up
Yeah nice edit dipshit
Old Feb 14, 2006 | 04:19 AM
  #45
TurboGibbs's Avatar
I answered your question. Maybe you need to ask the right question if you don't like the answer to your first one.
Old Feb 14, 2006 | 09:11 AM
  #46
thunder550's Avatar
High on diesel fumes
The connectors are not labeled, but the receptacle on the alt is labeled. L and F are the two terminals with the wires attached. One wire tells the alt to turn on (and at what voltage to run), the other reports back the duty cycle to the PCM. I thought that if I tapped into both wires the PCM would get confused, so I am letting one alt report back it's load level, but both are receiving the turn on/voltage signal.
The 118.25" belt (Napa p/n 061177) turned out to be a perfect fit. My old belt was a 113" I think (will verify), so it added about 5.25".
Old Mar 8, 2006 | 12:01 AM
  #47
Ron's5.3's Avatar
Just wanted to say nice setup. I am currently getting all the parts together for similiar setup with an aux battery. I am making a copy of the brackets off an install for a dual alt setup found at car audio site and alternator site. It uses a ford 130 amp alt. Real simple bracket and spacers. I got a delphi elec center with 12 fuses and 8 relays and got all the terminals for custom wiring it in to the aux battery.
One reason for the dual alts over a bigger alt is I will be able to get a replacement anywhere at anytime. I wont have to special order it or wait for it if I am in the middle of nowhere.
Old Mar 8, 2006 | 12:24 AM
  #48
thunder550's Avatar
It didn't work out so well with a single battery....the regulators in the factory alts are slightly different, and one won't kick on until the other quits running or there is enough load to drop the voltage significantly. I didn't want to mess with adding another batt, so the second alt is out. I may try to do it again at some point, but for now the project is dead for me.
Old Mar 8, 2006 | 12:26 AM
  #49
1slow01Z71's Avatar
How did that guy with the escalade or whatever do it?
Old Mar 8, 2006 | 12:52 AM
  #50
thunder550's Avatar
I dunno...I think he was using different regulators. I PM'ed him and got no response, even though he read the PM.
