Twin alt setup in progress, pics
Old Dec 18, 2005 | 01:40 AM
thunder550's Avatar
High on diesel fumes
Originally Posted by Holty
thunder550,
i think what your doing is cool, so please don't take this the wrong way...but why would you want to run 140amp and a 180amp alt's? why not just get a good quality 300amp or 400amp alternator? if you've gone this far in fabbing up your own, i'm sure you've already looked in to it and have your reasons why your doing what your doing. so, what kind of power draw do you have that makes you need that kind of charging power?
Ok here's the thought process. I had a single 200 amp before, burned it up for unknown reasons (aka increasing shifts from 5900 to 6300 rpm). I took it to my alternator guy to rebuild it, but in the meantime bought a 140 amp stock unit. 140 amps with a/c, e-fans, tranny cooler fans, offroad lights, and 2500 watts RMS of stereo doesn't go very far. I decided to go this route because buying a 140 from GM and rebuilding my aftermarket one was gonna be cheaper than buying a single 300 or 400 amp alt (assuming that I could find one, and assuming that the case would even fit...the 200 I had was huge to begin with).
Thunder I would definately be interested in one if the price is right. This truck will event lifted on big *** tires and a winch and offroad lights are going to be a must looks good. You might look into diesel belts the one on my dads powerstroke is long as hell and it has the dual alternator setup on it from the factory jsut a thought. That will be 10 bucks off my kit
I'll take a look at diesel belts, are they still 6 rib? Haha if we decide to sell them and the diesel thing works out I will give you your $10 discount
Originally Posted by CrabhartLS1
that'd be great for a system but probably not pushing enough to do say, an onboard welder or something.
I don't know what kind of amperage an onboard welder needs, but the alt guy told me the 200 I had before would run a welder. prolly couldn't keep 14 volts doing it, but he said it would go all day long. Just relaying what he told me, I personally have no idea.
Originally Posted by treyZ28
uhhh... putting them inline was a poor idea.
uhhh....wait till I'm done before you judge, I took the belt wrap into consideration. Or if that's not the reason, would you care to give your input?
Or should I just start guessing?
Originally Posted by thunder550
I still have a couple thigs to figure out, like where to get a freakin huge belt (130" or so) and how to mount an idler pulley between the alts to get better belt wrap .
Originally Posted by 1SlowHoe
Looks like he will have to fab a double idler. come straight down off the stock alt, go 90* over, them straight back up to the new alt. Hes gonna need a loooooong belt. If he can spread the double idlers apart even more he could get more belt wrap.
Even with a single idler I will still have just as much, if not more wrap than originally. Just gotta find a place to mount the pulley.
Old Dec 18, 2005 | 02:01 AM
treyZ28's Avatar
I'm not sure why you post pictures before you were done if you dont want people to judge it before its done?
common sense, no so common.
The first thing that is STRIKING is the belt routing. If the alternators were'nt inline the belt routing would be much much easier.
But no, you shouldn't start guessing. You should START by not being a saracstic jackass
Old Dec 18, 2005 | 02:40 AM
thunder550's Avatar
Ok ok I don't want to get into an argument...yes you're right about not posting pics before I'm done if I don't want to have them judged.
As far as where the alts mount, this was the least intrusive and easiest way that we could think of to do this. Everything is bolt-on, no welding, factory locations, etc etc. The brackets are very simple. What would you have done differently? (and I mean that seriously, not sarcastically)
I did ask for input, so rather than knocking the concept without an explanation, it would be nice to have you tell me what you thought and why. No hard feelings on my side, and I apologize for being a sarcastic jackass
Old Dec 18, 2005 | 02:50 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Just went out and checked my dads PS and it has 8 ribs you mgiht check into the older model vehicles Ill ask mjhoward he used to sell parts he mgiht know of something. Good idea man. Also for the idler pulley a 100mm unit down in between teh two a fwe inches lower that the alt pulleys would work well IMO.
Old Dec 18, 2005 | 06:43 AM
JimS's Avatar
Thunder.... I'm genuinely impressed with your mature attitude in the face of insulting and anger provoking comments aimed at you. I thought we were going to be off on a flaming war but you really handled that well. VERY cool.
Old Dec 18, 2005 | 07:30 AM
1slow01Z71's Avatar
I wish I was as cool as him LOL. Im fixing to go to the autoparts store thunder Ill check and see what they got for a 130"+ 6 rib belt.
Old Dec 18, 2005 | 08:24 AM
moregrip's Avatar
what a rush!
you can start here:
http://www.gatespowerpro.com/Comerge...nchInID=602155
Old Dec 18, 2005 | 08:30 AM
litreddevil's Avatar
Banned
i have seen this already and was nice the guy add a pulley to the factory pulley and then the alt. was hanging on the side of the factory alt.and it was it own tensioner.like the old trucks. he had that cause his bed was full of amps and speakers,he like 10 amps.it was a show truck.
Old Dec 18, 2005 | 09:30 AM
SSlow 4.8's Avatar
this should be intresting when its all said and done.... hell its all guess and check at this point. You gotta try and feel your way around to see what works, bc obviously there arent many ppl that do this type of thing... anyhow, when you get it done and working someday, maybe you can sell ppl kits w/ the alternators, lol im sure there wont be a HUGE demand for it.
oh and do you have any working alternators laying around? i'm looking for the 140a one from a denali or whatever truck it came out of... just something that is larger than our stock ones but will work as a direct connection rather than having to splice anything in.
Old Dec 18, 2005 | 09:48 AM
chevythunder06's Avatar
In the 12's??????
Thunder550, I found this thread over at gmfullsize,
http://www.gmfullsize.com/forum/show...light=aligator
The truck is rediculous, nothing I'd ever think of doing, but post #210 starts his install of dual alts.....Damn, he's Magnacharged too.
Hope this help a little. Try getting in touch with this guy about the intall if you can.
Later,
Jesse
