turbo without e-manage or electronics?
Old Feb 15, 2005 | 05:59 PM
mgm5886's Avatar
Default turbo without e-manage or electronics?
i was wondering if it is ok to run a turbo without e-manage, only running 5 punds of boost.... this is for a civic... no i am not a ricer, but my friend is..
Old Feb 15, 2005 | 06:04 PM
fullthrottledan's Avatar
if you have a wastegate that has a 5psi spring in it, you will be fine, if not get a manual boost contoller and turn the boost down.
Old Feb 15, 2005 | 06:14 PM
parish8's Avatar
single digit dreamer
you can't ever turn the boost down with a boost controler. only up.
my wg came with springs and shims that will let me go from about 5psi to about 10psi without any electronics or boost controler.
Old Feb 15, 2005 | 07:14 PM
That is an impossible question to answer. With so many variables involved, the correct answer will not be found.
Starting with 5psi, your going to want to check your plugs often, hook up a knock sensing device of some sort, and monitor your car closely.
If all is good, leave it alone. But my gut tells me that you would need at least a RRFPR if anything to at least supplement your fuel needs. As well as a better fuel pump if anything.
Now if your looking or max power from that engine, then an E-Manage or AEM standlaone is the ticket.
Old Feb 15, 2005 | 07:57 PM
oh i thought you could adjust down. I have 5lb springs in both wastegates and a manual, but ive only gone up, not down
Old Feb 15, 2005 | 08:32 PM
XLR8NSS's Avatar
Adkoonerstrator
I think Jim meant you can't below whatever the lowest setting is for the wastegate.
Old Feb 15, 2005 | 08:53 PM
parish8's Avatar
yeah i was but i think i missunderstood the original question. he may not have been asking about a boost controler at all but rather a way to tune.
i am with unredemed. no way to know especialy since i know nothing about a honda. on an ls1 the stock pcm would do a prety good job of tuning for you right up till you are out of injectors. it would be silly to spend the money on a turbo and not tune for it on an ls1 since they cost a lot but maybe you are geting it for next to nothing.
Old Feb 16, 2005 | 09:25 AM
mgm5886's Avatar
ok thanks for the info... we have e-manage and we are installing it today... its just last night we wanted to drive around with it and were not sure if it would run ok without it...
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
stock48
11
Aug 18, 2015 05:55 AM
OHsixLS3
Aug 10, 2015 07:19 PM
