TSP F-Body 1 7/8 LT's on a 2006 ISS
Old Aug 22, 2014 | 06:42 AM
  #21
JDC's Avatar
JDC
Originally Posted by Tyson1972
Mike I will definitly post up some pics tomorrow when it light out.
JDC is your truck a torsion bar front end or a coil spring set up? Also are you running the
1 3/4 or 1 7/8 F-Body Headers?
Its a spring frt end and thier 1 7/8
Old Aug 22, 2014 | 09:52 AM
  #22
Tyson1972's Avatar
No LPCWS6 I knew it was a different frame. I just didnt know for 100% that the headers would fit our not. I was asking on this forum if anyone here has tried to fit them on their trucks. I knew there would be a chance they would not fit perfectly but the fitment isnt that bad at all. Just a little modification is all.
Old Aug 22, 2014 | 02:42 PM
  #23
Mikey 97Z M6's Avatar
11 Second Club
Nice,,,, curious how much modification to the frame is needed.
Mike
Old Aug 23, 2014 | 07:27 PM
  #24
Tyson1972's Avatar
How do y'all add pics on here from a IPhone?
Old Aug 23, 2014 | 09:19 PM
  #25
Tyson1972's Avatar
Here are some pics so far guys.
Attached Thumbnails TSP F-Body 1 7/8 LT's on a 2006 ISS-img_0561.jpg   TSP F-Body 1 7/8 LT's on a 2006 ISS-img_0563.jpg   TSP F-Body 1 7/8 LT's on a 2006 ISS-img_0564.jpg   TSP F-Body 1 7/8 LT's on a 2006 ISS-img_0565.jpg   TSP F-Body 1 7/8 LT's on a 2006 ISS-img_0568.jpg
Old Aug 26, 2014 | 10:14 AM
  #26
11 Second Club
So this is the part of the frame that was cut/modified to fit the header? Do you have any better pics of this area? It's hard to get any orientation as to where this is on the frame etc... Was this taken with the header in its mounted position or is the header unbolted and laying off to the side?
Mike
Old Aug 26, 2014 | 12:17 PM
  #27
Tyson1972's Avatar
I dont but I will take one today. Yes it was cut with a sawzall and a grinder. Its not perfect but I will clean it up and weld some support pieces in there to clean it up some and make it look better.
Old Aug 26, 2014 | 04:48 PM
  #28
Tyson1972's Avatar
Here is a better picture Mike. I still have some trimming to do as you can see by the white paint marks. I will probably cut it again with my sawzall and weld it up before I remount the header. I got all my stock trans lines, fittings & trans cooler out yesterday. I only had one fitting and line to pull today. I mostly had things to do around the garage & for the family.
Attached Thumbnails TSP F-Body 1 7/8 LT's on a 2006 ISS-img_0588.jpg
Old Aug 27, 2014 | 09:32 AM
  #29
11 Second Club
Aaahhhh that clears it up. Thanks man.
Mike
Old Sep 2, 2014 | 02:14 PM
  #30
11 Second Club
So did you ever get the header installed and fitting correctly? Any pics of the clearance after the frame mod?
Mike
