truck surges under full throttle with less than half a tank of fuel
Old Nov 6, 2013 | 08:15 PM
tempoffroad's Avatar
Default truck surges under full throttle with less than half a tank of fuel
I have a 1990 C 1500 with lq4 swap I have 42 pounds injectors and a 255 pump it seems that anything under a half a tank if I floor it from a stop it will start surging. can I be sucking the fuel bucket dry
Old Nov 6, 2013 | 09:53 PM
cosb's Avatar
I had the same problem with my lq4 back when it was stock, it was the fuel pump. The lower the gas tank, the worse it got.
Old Nov 6, 2013 | 09:55 PM
cosb's Avatar
Btw i still had the factory pump and bucket when it happen to me.
Old Nov 6, 2013 | 10:35 PM
Atomic's Avatar
I have a gauge for that
Could be, yep.
Old Nov 6, 2013 | 11:29 PM
brandon6.0's Avatar
Very possible. A lot of guys including me cut the bottom out of the bucket and sit the fuel filter on the bottom of the tank. That way there is no chance of the bucket getting sucked dry. With mine like this I can get pretty low without issues except on really hard launches. Less than a 1/4 tank.
Old Nov 7, 2013 | 06:06 AM
Thank I will pull pump and look may just go ahead and install 450 pump and cut up bucket. It seems to get worst as it gets lower. Thanks
Old Nov 7, 2013 | 03:17 PM
I would guess that your fuel pump pickup is not properly seated "in the bucket" or you have alot of crud floating around in the fuel tank obstructing the flow. Either way you should drop the tank and see what's going on...don't just automatically start throwing new parts at it.
Old Nov 7, 2013 | 04:41 PM
cosb's Avatar
i find it to be a huge pain in the *** to get your fuel pump out, so i would just change the pump and filter while its out. the walbo 255 is only around $100
Old Nov 8, 2013 | 08:59 AM
It already has a 255 pump thats less than 6months old. I didn't find it a pain to pull the pump I just lift the bed off less than an hr start to finish.
Old Nov 8, 2013 | 11:37 AM
cosb's Avatar
I lifted the bed off too, i found it to be easy but a pain. Btw I had a 255 pump die after only about 8 months.
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
