Trouble codes after header install
Hi all, I'm getting the following trouble codes after an exhaust shop did the header install. The said they had to jack up the engine in order to get the passenger header installed. It looks like one of the codes is ECT, where is this sensor located? Any ideas on these codes?
Diagnostic Trouble Codes
P0118 "Engine Coolant Temperature (ECT) Sensor Circuit High" EPA ($10) "Powertrain Control Module (PCM)"
P0118 "Engine Coolant Temperature (ECT) Sensor Circuit High" EPA Pending ($10) "Powertrain Control Module (PCM)"
P0118 "Engine Coolant Temperature (ECT) Sensor Circuit High" MPHC ($10) "Powertrain Control Module (PCM)"
B2961 "Key in Ignition Circuit " H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
Never mind, dipshits at the shop never reconnected the ect wire. They also managed to break the damn clip that keeps it connected. Oh well, it sits in there pretty well without being clipped so I'm just gonna let it be.
zblee
63
Jun 10, 2023 01:25 PM
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
lxcoupe
Jul 21, 2015 02:12 AM
