Tried to install Comp Pro-mag rockers. WTH?
Old May 14, 2005 | 09:32 PM
Default Tried to install Comp Pro-mag rockers. WTH?
I installed comp pro magnum rockers on my 99 silvy (4.8). The valve covers don't fit over them. Anybody have this problem? ( or solution). I'm slighty pissed because the are supposed to fit under the stock valve covers.
Old May 15, 2005 | 12:57 AM
how much are they not fitting by? would a set of THICK gaskets help ( the got them for the SBC anyway)
Old May 15, 2005 | 12:59 AM
99Silver6.0's Avatar
Youll probably need some valve cover spacers. Thunder sells them. Or you could get some of Nasty Performances or Katechs valve covers.
Old May 15, 2005 | 06:54 AM
tdrumm's Avatar
There's also a sheetmetal baffle on the underside of the cover. If that is all that is hitting, you could trim it a little.
Old May 15, 2005 | 09:43 AM
Hunter's Avatar
I removed all the baffles under my valve covers. Plenty of clearance then
Old May 15, 2005 | 10:48 AM
So what can I do to stop the PCV from sucking oil now that there are no baffles? I did remove the driver side baffle, but it still doesn't fit. It seems I might have to grind on the covers too.
Old May 15, 2005 | 11:12 AM
Get the LS6 valley cover. That setup will no longer pull PCV air from the valve cover. It will pull it from the valley area that is under the intake manifold.
Old May 15, 2005 | 11:17 AM
litreddevil's Avatar
Banned
I Though This Fit Under Stock Covers I Have Mine And Never Put Them On Yet.have You Con Contacted Comp Yet.
Old May 15, 2005 | 11:39 AM
tdrumm's Avatar
I think on the center mount covers, you might have to grind just a little around the bolts holes too.
Old May 15, 2005 | 02:54 PM
Be prepared to be really pissed!!!. You're gonna go through the same thing that I ( and everyone else) am.
Dan Neumann
11
Aug 7, 2022 09:06 AM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
