transmission with "oil" question "what"
Old Nov 28, 2003 | 07:42 AM
Kano's Avatar
Default transmission with "oil" question "what"
Ihave a friend who just blew up his transmission and got a new one replaced
the transmission tech told him to substitute 1 qt of fluid with 1 qt of
30 wt non detergent motor oil
he done it and ended up doing this to every 1 of his vehicles he said it made it shift better etc etc
i was just wondering does any1 know anything about this or how it works
Idont get it ??????????????????????????????????????????????????
Old Nov 28, 2003 | 09:51 AM
one03sierra's Avatar
Formerly one92rs
not sure about that.Century automotive put mine together and filled it with Royal Purple. i dont think i would put motor oil in any transmission.engine oil is to lubricate the engine-engine oil-.tranny fluid is for transmissions.
call---281-633-8155 monday and talk to craig or mike.
Old Nov 28, 2003 | 12:57 PM
L-EATER's Avatar
11 Second Truck Club
I know a couple of Dodge boys who use 5w30 mobil one motor oil in their trannys. It takes care of the "shudder" they have. One of the reputable local trans shops turned them on to the idea. I wouldn't use it in any of my vehicles though.
Old Nov 28, 2003 | 01:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would not suggest doing this AT ALL.
Transmissions are Hydraulic, engine oil will foam up in the trans.
Old Nov 29, 2003 | 03:09 PM
OBXMarine's Avatar
I agree, engine oil is for engines and transmission fluid is for transmissions.
Installed a tranny for a friend on his old surdurban a few years back. a few days later, he went to his mechanic and he recommended adding a quart of Tranny fluid to the motor and drive it for about 1000 miles or so to "Clean out the engine". Well a couple hundred miles later, the engine goes
I told him not to do that, but if he did, just let the engine idle in park for about 5 minutes, then change the oil. Used to do this with Kerosene to clean them out.
Kinda off topic, but the principles are the same...
Old Nov 29, 2003 | 03:33 PM
XLR8NSS's Avatar
Adkoonerstrator
FWIW, my dads Exmark grass cutter uses Mobil One 5W30 motor oil for the hydraulics. The wheels are driven by a hydraulic pump and it uses Mobil 1 motor oil. That's what they recommend. Must be some bada$$ stuff.
I don't think I could pour a quart in my transmission though.
ferrellrooster
Mar 6, 2025 03:22 PM
zblee
63
Jun 10, 2023 01:25 PM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bsn1989
Jul 16, 2015 08:20 AM
