Transgo+servo spacer HELP!!!!
Old Jun 8, 2004 | 09:50 PM
Hit Man X's Avatar
Originally Posted by mudz5.3
Yeah, well I will be talking to you when I put the stall in, k
You can talk to me if one of your girlfriend(S) has a bmw that breaks; how about that!!
Sure, lemme know...I'll be happy to help. BMW is a VERY nice ride. One of my pals has an '02 328i 4 door. I keep tellin' him to get an M3 w/ that SMG tranny.
You've got it about the feed holes, just ever so slightly larger...if need be.
HP ones on stock stall - ~.082 1-2; ~.093 2-3; ~.082 3-4
HP ones on high stall - ~.120 1-2; ~.097-.100 2-3; ~.120 3-4
I'm unsure if with the Yank stalls the feed holes will need opening. It's a pretty tame stall compared to a smaller diameter PI. We'll see once Mudz or I get it installed.
Old Jun 9, 2004 | 03:14 PM
TigerFan187's Avatar
Thanks for all the help let me ask you guys this though! Like you see I have the Transgo+vette can I and would you recommend getting the overdrive servo(billet) with the setup I already have (transgo+vette)?
Old Jun 9, 2004 | 03:22 PM
Hit Man X's Avatar
Yes you can install it with your setup and yes I'd get one. It increases 4th gear holding of the band by ~50%! 4th is super weak in these trannies. Just pop the cover, pull the lil E-clip, the small spring should come off, then the 4th apply servo. Install is reverse of removal.
Old Jun 9, 2004 | 05:06 PM
revolution's Avatar
i have the yank TT2600, vette servo, transgo and no washers. i chirp 2nd but not third. i would go with zero washers
Old Jun 9, 2004 | 05:08 PM
revolution's Avatar
i still need to get one of those... but why is it so expensive??? the vette servo is cheap.
Old Jun 9, 2004 | 05:22 PM
mudz5.3's Avatar
Because the billet is machined and is not mass produced like the vette servo.
Old Jun 9, 2004 | 05:31 PM
Hit Man X's Avatar
Exactly, the stock OD servo and 'Vette ones are EVERYWHERE. Used billets pop up on occasion. Keep an eye out for them. It's a good upgrade for performance and even better for some towing.
calsdad
Jun 14, 2023 11:07 PM
OHsixLS3
Nov 22, 2015 07:45 PM
OHsixLS3
Sep 25, 2015 11:20 AM
zraffz
Sep 8, 2015 07:40 PM
