Transgo+servo spacer HELP!!!!
I know this has been tlaked baout many times I'm sure but this will realy help me alot. Im getting a Transgo+vette servo as well as a cooler installed and I need opinions on how many spacers to use for the 2nd accum. Its a auto 60e and I wont be getting my yank for a while! I want it to be firm but not weak so any opinions will be greatly appreciated. New tune form Allen will have 0 TM and oe pressure!
Originally Posted by mudz5.3
I'd say none until you get the yank. I hated having one in there. Still not sure if I'll put one in when I put my yank in either, but we'll see.
When you install it, let me know.
I wonder if you'll need larger feed holes or anything...
Lemme know when you install it what you decide to do. Perhaps larger feed holes?
Not sure, you know more about that than I do about the feed holes, I just listen. I posted about adding a washer when I put the stall in, don't remember the replies though. I think it was mixed though.
Tiger, listen to hitman, or flyer if you have any more ?'s. Not saying that nobody knows as much as them but they seem to be more knowledgable when it comes to the trans kits.
As soon as I get a stall put in, I'm gonna play with the VB a bit for shifts. Feed holes probably, toss a few check *****, etc.
Basically to sum it up tiger; With the shiftkit and corvette servo, you might want to try one washer in the second accumulator. If you had the billets then I would recco no washers. When you get a stall you will want one washer if you have the vette servo's, maybe two. What hitman and I are talking about is opening up feed holes in the valve body instead of just using the washers in the second accumulator. Since the second accumulator only affects 1-2 shift then feed holes and the 3-4 servo helps 2-3, 3-4 shifts. Hitman likes to enlarge the feed holes, in my eyes doing it properly not just making the tires chirp on 1-2 shift. So the finale is, use 1 washer with no stall and corvette servo. If you go with billets, use no washer. When you get a stall with vette servo, 1 washer if not 2. Also get numbers from hitman as far as the feed holes is concerned.
