egr question ?
Old Jun 8, 2004 | 08:54 PM
Default egr question ?
I just cut the egr off in my intake manifold and I also cleaned it out with carb cleaner. Now it idols ruf and whenever i touch the gas it goes up to 2000 rpms and takes a few seconds to go back down to idoling. Is this because of the carb cleaner or cutting the egr short? Also, can I turn off the egr sensor with nelson's tune and just plug the holes?
Old Jun 8, 2004 | 09:40 PM
jlwz71's Avatar
You may have not seated the black O-ring properly on the intake manifold or you may have damaged it. Basically you have a vacuum leak.
Old Jun 8, 2004 | 09:53 PM
ThunderZ28's Avatar
12 Second Club
yes you can have Allen turn the EGR off. you would need to block the EGR tube on your header, and plug the hole in the side of the intake with a freeze plug.
Old Jun 8, 2004 | 10:07 PM
Hit Man X's Avatar
That's a lot of work. I just made a gasket from a big sheet, cut it to size, and put it between the EGR valve and the tube from the exhaust manifold to the intake.
Old Jun 8, 2004 | 10:13 PM
ThunderZ28's Avatar
12 Second Club
or you can do it the Hit Man X way
I did mine the other way just because it cleaned up the engine a bit.
and removed it completely
Old Jun 8, 2004 | 10:20 PM
Hit Man X's Avatar
Sure it'd make it cleaner but where is that extra harness going to go?
Old Jun 8, 2004 | 11:01 PM
It must be the o-ring. I hope those things arent hard to find. Thanks for the imput.
Old Jun 9, 2004 | 06:42 PM
ThunderZ28's Avatar
12 Second Club
thats my secret.
you have to look real close to find it
plus it's turned off so it doesnt do anything anyways.
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
Pimpinpete
Sep 8, 2015 07:39 PM
