Trans didn't shift
Old Aug 21, 2004 | 03:29 PM
Lilbro665's Avatar
14 Second Truck Club
Default Trans didn't shift
Last night I went out to the track and tried out some new jets in my Nitrous System. The engine ran fine but the trans just wouldn't shift at wide open. I tried maual shifting and just leaving it in drive. the only way it would shift is to back out of the nitrous and let the trans shift. The trans shifted fine with a smaller shot of nitrous in it. Any help will be appreciated. Thank You.
Old Aug 21, 2004 | 03:36 PM
2toneblown's Avatar
Mine just did the same exact thing. I even went and bought a built 4L60 and it was worse than the stock one. My truck is one the lift right now getting a built 4L80.
Old Aug 22, 2004 | 08:28 PM
Lilbro665's Avatar
any body?
Old Aug 23, 2004 | 07:56 AM
I can't get mine to shift into 3rd at WOT either, so I'm in the same boat as you.
Old Aug 23, 2004 | 04:19 PM
Lilbro665's Avatar
Just talked to a guy that works with Delphi and he said to not run n2o with out a custom tune. If you do you will lean out #7 and break the wrist pin or burn a hole in the piston. so im taking off the N2O and going naturally aspirated untill I can afford a turbo sys and a good tune!
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
lycominghunter
Aug 15, 2015 12:26 PM
KyleW707
Jul 29, 2015 08:17 AM
lxcoupe
Jul 14, 2015 10:14 PM
