Traction advice
Old Sep 20, 2004 | 06:29 PM
derek_silvy's Avatar
Default Traction advice
With my current set up, I need traction!
I have an open differential, so I only spin one wheel..... and man, does it spin. I bet I have another second to shave 0-60 if I could just get traction. Right now, if I put it to the floor anywhere in 1st gear I start spinning or if I don't floor it I end up shifting at about 4300, which sucks.
Alright..... which differential should I get? What other kind of things like traction bars can I get to beef up the rear suspension. I will continue using the 255 tires until they wear out at which time I may buy new rims and wider tires.
Any advice here?
Old Sep 20, 2004 | 06:41 PM
Flyer's Avatar
Eaton Posi
If traction is still an issue, look for tires or traction bars.
Old Sep 20, 2004 | 06:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
I ran the Auburn Pro Series in my last truck and never had any issues with it.
Old Sep 20, 2004 | 07:06 PM
What kinda power were you putting out to that auburn and what kinda traction did it provide?
How is that eaton posi? How much was it? What all is involved in the install?
Old Sep 20, 2004 | 07:14 PM
Flyer's Avatar
I think there is about 20 bucks difference and no difference on the install. About the only difference is the Eaton is rebuildable and the Auburn isn't. I've heard some guys wish they had gone with Eaton, but nothing about the Eatons.
The Eaton hooks! Plain and simple. I've run some 12's on it so it's taking a little bit of power.
Old Sep 20, 2004 | 07:20 PM
Dark Halo's Avatar
where can you get traction bars? Will any standerd traction bar work?
Old Sep 20, 2004 | 07:23 PM
What kinda mods have you got?
Can you just kinda breif me on the install?
Thanks,
Derek
Old Sep 20, 2004 | 07:36 PM
Flyer's Avatar
Here's the way my install went:
Jack up the rear, do it on a gravel/dirt driveway and you'll see why it's worth putting in a how to.
Take the tires off
Remove break calipers with a HUGE breaker bar
Remove rear cover
Take 3 days to figure out how to get the C clips out of the carrier
Pull the axles out
Remove the diff, which again took a good while because it's PRESSED into place
Beat on the pinion with a sledge
Pound on the pinion gear with a air hammer you just went to get
throw it all back together half assed
get some stock wheels/tires from a friend to swap with so you can get it on a trailer
load it up using the winch on my Grizzly since it's not drivable
Carry it to a professional and explain to them what happened
Long story short ... get someone to do it. That way it's on thier shoulders and if they whine, you can get them to fix it.
Old Sep 20, 2004 | 09:30 PM
How much did it cost you to get it put in? The truck is useless from a performance standpoint with this little traction, but I am finding a job with less hours (I can't work 55 hours with full time college) and I have this tranny to pay for.
So lets see, about 450 for the diffy... then another what.... 200 for the install? Can any ol tranny shop do it?
Old Sep 20, 2004 | 09:46 PM
Flyer's Avatar
I'd go to a 4x4 shop to get the diff changed. One shop I called quoted 325. The next shop quoted 200.
