tr55's?
Old Feb 26, 2010 | 10:43 AM
getchusum99's Avatar
Default tr55's?
what plugs you guys runing for mostly stock applications on your 5.3? and what wires do you reccomend? i have talyor thundervolts on there now but they have about 80k on em and ive already broke 2 of em.
Old Feb 26, 2010 | 11:37 AM
budhayes3's Avatar
PT's Slowest Truck
I'm currently running TR55's gapped at .055 with MSD wires which fit nicely with my StainlessWorks Long Tubes. I may be able to fit stockers on their also, just haven't tried.
Old Feb 26, 2010 | 12:09 PM
Parke10's Avatar
TR55's Here
Old Feb 26, 2010 | 12:47 PM
zachm89's Avatar
tr-55 iridiums with Taylor 10.4 wires...wouldnt replace them with anything else
Old Feb 26, 2010 | 12:56 PM
sonoma43's Avatar
TR55's with MSD wires
Old Feb 26, 2010 | 01:48 PM
1Bear's Avatar
I run TR-6 plugs and MSD wires and am quite pleased with them, but due to fitment issues with the Dynatech headers I had custom wires made with 90deg boots and they fit too snug to the heads. So while I dont recommend that everyone run out and buy a set, I think the next set I try will be the MTI Racing wires, as they have 115deg angled boots on the plug end and should help with the header clearance while not being too tight to the heads. Of course, the better solution would be a set of headers that didn't have the stupid humped up tube!
Old Feb 26, 2010 | 03:56 PM
viciousknid's Avatar
Where's the Beef?
TR55 with Stock wires. There is no power increase in the wires so only switch them if you want it to look purdy
Old Feb 26, 2010 | 05:31 PM
1Bear's Avatar
Agreed, the only real purpose to change them would be if you just needed a new set of wires or like in my case for fitment purposes, but other than that I can't think of another good reason to ditch the stock wires (maybe the purdy thing).
It's not like it was on the older motors where a plug wire may be 3ft long or so and had a horrendous ohm load or voltage drop. It's hard to have much of either with an 8in long wire.
Old Feb 26, 2010 | 06:30 PM
budhayes3's Avatar
PT's Slowest Truck
The ignition systems have come a LOOONG way since back in the day too
Old Feb 28, 2010 | 01:35 PM
i plan on doin pacesetter lt's also and , should i buy a thicker set of wires to help protect them from the heat ,or get the stock replacement bosch ?
