Towing package (weight removal)
Old Mar 18, 2004 | 10:13 AM
F8L Z71's Avatar
Default Towing package (weight removal)
Just a heads up for those with the towing package that never tow anymore like myself.
I just removed mine before I head off to work and it was definately worth the effort. Took about 5min of actual work (5more to find my tools).
Net loss?
33lbs!!!
It may not seem like a lot but add 10lbs for the front skid plates and 10lbs or so for the clutch fan/shroud and that's about 50lbs of permanent weight gone.
So now on race days I have a total of about 253lbs removed. Not too bad for not much work.
Anyone have any other cool weight removal tips on stuff we don't need?
Old Mar 18, 2004 | 10:18 AM
ThunderZ28's Avatar
12 Second Club
i removed mine and had the heavy duty one, took me and one other person to get it on, an off, heavy as hell
Old Mar 18, 2004 | 11:37 AM
leochevy2001's Avatar
Can the wiring be removed also or is it better to leave it?
Old Mar 18, 2004 | 11:45 AM
ThunderZ28's Avatar
12 Second Club
you mean for the connector?
yes it can just depends on if your ever going to tow with it again.
Mine is coming off, cause i'm not going to tow with it anymore.
Old Mar 18, 2004 | 11:54 AM
Yes, the connector and all the wiring that leads to the steering column or at least I guess it goes to the steering column. I don't plan on towing with it. I didn't even plan on putting stuff in the bed but I had to (moved 4 times).
Old Mar 18, 2004 | 03:07 PM
ThunderZ28's Avatar
12 Second Club
wires should be tucked up behind the rear bumper. thats where mine where when I tapped into them for the connector. I'm just gonna cut the wires there and tape them back up.
Old Mar 18, 2004 | 04:18 PM
Sounds good to me.....Thanks 01!
Old Mar 18, 2004 | 04:28 PM
parish8's Avatar
single digit dreamer
i ditched the spare, spare winch, jack, jack handle, tow hooks, lift blocks, skid plates.
i plan on doing a roll pan some day to get rid of the bumper.
and at the track i will pull the gate and pasenger seat.
Old Mar 18, 2004 | 07:20 PM
FILE's Avatar
This is a luxury of having a 4x4. I tried taking the spare off and tailgete and already had traction problems.
Old Mar 18, 2004 | 07:25 PM
Flyer's Avatar
Get some stickies ... you'll have no more traction problems then.
