Torque specs for the crank bolt
Old Sep 7, 2004 | 08:56 AM
FILE's Avatar
Default Torque specs for the crank bolt
Anybody knows how tight that crank bolt goes?
Old Sep 7, 2004 | 09:38 AM
derek_silvy's Avatar
240ft/lbs sticks out in my head right now...
Double check though
Old Sep 7, 2004 | 09:51 AM
FILE's Avatar
OMG, I left it at just under 100.
Old Sep 7, 2004 | 09:56 AM
Stock bolt, or ARP? I think they are different.
Stock bolt has a stretching procedure. You take your old bolt and torque down to 240ftlbs to push pulley on. Then remove it and take a new bolt and you torque to 37ftlbs, then turn an addit'l 140 degrees.
Under 100ftlbs, you will spin your pulley off of your crankshaft.
Old Sep 7, 2004 | 10:29 AM
FILE's Avatar
It's the stock bolt. The pulley was pushed all the way then the bolt was loosened up and then torqued to about 90ftlbs. Locktight was added to the bolt before it was put in.
Old Sep 7, 2004 | 10:56 AM
I wouldn't drive it much like that. I'd back it out, torque to 37ftlbs and then do the 140 degree thing. I've only been able to do 120 degrees at the most, and never had issues.
Old Sep 7, 2004 | 11:31 AM
vanillagorilla's Avatar
Old Sep 7, 2004 | 12:28 PM
Flyer's Avatar
I just beat the snot out of mine with an impact wrench. I figured that would have been as tight as I could have gotten it anyways. I checked it a few days later and retitghtened it. I got maybe another 1/4 turn on it and called it good. I've checked it a time or 2 more and haven't been ablke to get much on it.
Old Sep 7, 2004 | 12:55 PM
marc_w's Avatar
Yeah, I do the "37ft/lb to as tight as I can go" method. I was hanging off a 4' breaker Sunday, and only got around 120*.
Old Sep 7, 2004 | 12:56 PM
Mine was 4' too. And here I thought I was just being a little weak.
black00chev
Aug 12, 2015 01:56 PM
vipergtrdj
Aug 6, 2015 10:19 PM
OLD BULL
Aug 1, 2015 05:00 PM
NuckenFuts
Jul 9, 2015 08:45 AM
GreyChevy
Jul 7, 2015 08:57 PM
