Torque converter bolts??
Old Apr 26, 2005 | 12:08 PM
Wilde Racing's Avatar
How do I change this text
Default Torque converter bolts??
I just ordered my new 4l80e trans and conversion kit. I also ordered all the needed hardware for the conversion. I will be running a 4l60e torque converter. (with the three bolts). Is the three bolts going to be strong enough??
Old Apr 26, 2005 | 12:11 PM
Yelo's Avatar
I certainly wouldn't.......that's the only connection between the engine and transmission and I'm pretty certain that three 7/16" bolts aren't going to hold the power of a boosted motor very long
Old Apr 26, 2005 | 12:12 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yup they will if Allen's tranny bolts are holding up to the horsepower he is making then it will work just fine for you.
Old Apr 26, 2005 | 12:15 PM
Yelo's Avatar
....I'd still be scared....but if Allen can do it maybe I'll look into a 4L60e converter (they're ALOT cheaper than a 4L80e converter)
Old Apr 26, 2005 | 12:42 PM
I still have time to change my order, But I was told by sells at Speed Engineering, that three bolt would be fine. (they have a 800+hp car with 60e converter) I just wanted to hear some other thoughts on it.
Old Apr 26, 2005 | 01:11 PM
Yelo's Avatar
Hell...I've been wrong before, go for it and let me know how it works out.....if it works well I'll probably go for a 60e converter instead
Old Apr 26, 2005 | 01:36 PM
soldeir's Avatar
yeah I agree
Old Apr 26, 2005 | 01:38 PM
kbracing96's Avatar
1-7/16 grade 8 bolt has a shear strenth of 10680 lbf at the threads (http://www.hobson.com.au/class_8.htm), so I would think that the bolts would not be the issue. Most likely the flex plate would brake before the bolts, but I think with you power level, you would be fine with 3 bolts.
TAPyvehc93
Jul 23, 2017 10:54 PM
OLD BULL
Aug 1, 2015 05:00 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
