Top Speed Tips? How Fast?
#41
High on diesel fumes
I should of mentioned and it might help to know that these pictures were taken when the truck was up on a lift. Not sure what the name of the lift is but it picked the truck up from the frame so the rear end and drive shaft was hanging down. In actuality there isn't...8 inches of clearance or else my turbo would of been nicked as well.
Hope this helps anyone else thinking about taking these trucks past their designed limit. It was fun though!
Wow ok that makes more sense now. I was figuring that the stock aluminum DS was made of string cheese or something to hit from that far away.
#43
I had it faster but it isn't safe. I am with Zippy,...bed cover, tighter shocks, lower, better wider tires and a high speed balanced drive shaft.
Where I am at, a deer can pop out of the woods in a matter of a second. swerving is out of the question at those speeds so you have to have it made up in your mind that you are going to pancake it and suffer the loss of your truck in trade off for your life.
Like mentioned earlier,...I just want to 0-120 as fast as possible on the strip and 0-60 as fast as possible on the street
Cowboy Tom
24
02-11-2017 08:20 PM
thewrx
08-12-2015 08:28 PM
