too high oil pressure?
Old Aug 8, 2006 | 01:44 AM
Default too high oil pressure?
After my initial start of the engine with a hi volume oil pump on my guage it showed the pressure to be on the line just under the 550 and when it revved it went to 550...+...? Now that I have it apart again should I swap the spring for the lower pressure one? Keep in mind that I am installing a supercharger and a seperate oil filtration system before the super so mabey I need the added pressure to make the round?
Old Aug 8, 2006 | 03:36 AM
jblack6527's Avatar
I have heard alot of the older racers and some of the new say that 10 psi per thousand rpm is enough, but i personally like all i can get.. When you say 550, what exactly do you mean?
Old Aug 8, 2006 | 04:43 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That true to a certain extent if you have too much you can wash the bearings out. I would shoot for no more than 80psi at WOT. I dont know what the 550 is referring too
Old Aug 8, 2006 | 05:13 AM
Quik's Avatar
5 year bitches!
old school kill LSX with their knowledge dont listen to ppl from oldschool when you have a LSX they are totally different.
if you should have around 40ish at warm idle and near 70ish for WOT. anything less then that i would check things out
Old Aug 8, 2006 | 10:37 AM
on my stock guage cluster the oil pressure starts at 0 then theres a 1/4 line then 275 then a 3/4 line then 550 kpa. At idle my needle is at the 3/4 line then at higher rpms the needle goes to 550kpa or higher.
Old Aug 8, 2006 | 10:47 AM
silver-mod-o's Avatar
Hunt&Fisherator
hhhmmm a canuck eeehhh?!?!?
Old Aug 8, 2006 | 11:29 AM
and a redneck to boot....YEEEHAWWW
Old Aug 8, 2006 | 11:42 AM
Your kPa reading is about right compared to a psi reading with a high volume oil pump. Your 550 kPa reading is equivalent to right at 38psi.
I would leave your pressure where it is. Don't take it down any. Supercharged or not, I would keep the higher pressure.
Jim
Old Aug 8, 2006 | 03:17 PM
thank y'all for the info
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
