Just a click? Need help asap please!
Old Aug 7, 2006 | 10:33 PM
mds2004's Avatar
Default Just a click? Need help asap please!
Alright well first of all I just put in new motor in the Yukon and I am ready to fire it for the first time.
However all I hear is a click and so I pulled out the starter and let it hang while still connected. It just clicks and pops out with no spin. However it is also a brand new starter and I had it tested which it came out good. So after this I put in a new starter relaya nd still the same problem. What could be causing this? This is all I need to start my new motor and my anticipation is killing me! Thanks in advance, Mark.
Old Aug 7, 2006 | 10:39 PM
mds2004's Avatar
Forgot to add that I also have a brand new battery as of yesterday. Voltage is at 14 and I also tried jump starting it. Still no luck.
Old Aug 7, 2006 | 11:02 PM
maybe some of your wires arent connected securely or correctly?
Old Aug 7, 2006 | 11:37 PM
mds2004's Avatar
Alright well I got it working. Thanks for the help guys. Now it is surging and dying when put into drive.
Old Aug 7, 2006 | 11:42 PM
fuel delivery problems?
Old Aug 8, 2006 | 12:30 AM
Wheatley's Avatar
Truck Sponsor
What motor is in it?
Old Aug 8, 2006 | 01:04 AM
shandy294's Avatar
What was wrong with the starter?
Old Aug 8, 2006 | 01:05 AM
RoosterMcCandles's Avatar
That does sound like a problem with fuel delivery...
Old Aug 8, 2006 | 10:51 AM
negativeswitches's Avatar
did you put a bigger cam in it? it may require tuning
Old Aug 8, 2006 | 03:33 PM
mds2004's Avatar
Reinstalled the upper intake manifold and it is fine now. Must have been a leak there. Anyways engine specs are:
4 Bolt Main
2.5" dual Dynomax Bullet custom exhaust
Magnaflow X Pipe
Hypertech 180 degree thermostat
Allen Nelson tune
Doug Thorley headers
Comp Cam's cam (218/224 at .050, .570/.565, 113 LSA)
Comp Cam's 1.6 roller rockers
Comp Cam's hydraulic roller lifters
Eagle 383ci cast steel stoker crankshaft
Eagle SIR rods
CVP Oil Pan
Speed Pro hypereutectic pistons
Static 9.9:1 compression ratio
More infor can be found in my cardomain site in my sig
http://www.cardomain.com/ride/2081389
Pimpinpete
43
Dec 22, 2017 08:13 AM
dsbodley
Nov 14, 2015 09:46 PM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
