Timing gear help.
I got the cam from vengeance, they said 7.4 should be fine. I thought you could stay stock length till .040. were thinking maybe the cam is wrong. What would make the compression so much higher an have to add so much air?
Baltimore Whore
Didn't you make a thread asking about what push rods to use on milled heads a while back. A 7.4 rod is not going to work with a 30 thou mill 10 or 20 yes. I get away fine with 20 thou off and a 7.4 rod. Stock length is infact 7.38. Should have measured to be sure.
iregret
07-27-2015 10:32 PM
MileHighSierra
07-22-2015 11:19 PM
GMCtrk
07-17-2015 06:39 PM
Nimoryan
07-05-2015 03:50 PM
