Throttle body spacer = Rough idle
Old May 2, 2013 | 03:49 PM
goinbrokez28's Avatar
Default Throttle body spacer = Rough idle
When I first bought my truck it was around my B-day, and my mother ordered me an Airraid TB spacer. I felt the same way about them as everyone else does but figured it wouldn't hurt and proceeded to bolt it on with plans of Nitrous later.
Now, my problem did not start there, but around the time I Installed my P&P Throttle body from Peak Speed (Bob is local and a good guy to deal with) and my Black bear tune. My idle became very sporadic on cold starts and a little sporadic when warm as well as a slight stumble at stoplights when light throttle was applied (intermittent). Since drivability seemed to be fine, I figured it was just a mix of the new TB and tune and sort of dealt with the issue.
Well, I have had a lot of time on my hands lately and decided to remove the spacer since I had nothing better to do.
Once the spacer was removed I started her up and....you guessed it, I had a perfectly smooth idle from cold to operating temp. It no longer idles as high as it did when cold and (this may be a placebo effect) part throttle drivability seems to have improved as well as throttle response, again that may be the placebo effect.
I did some searches and could not find anyone one on here with similar before and after results, so I figured I'd make a thread just in case someone was having these same troubles.
Also, I cant find it anymore but this morning after google searches, I found another forum where a member stated that a tuner told him the spacer disrupts airflow and throws off the MAF sensor. Maybe this was my issue.
Well thanks for reading and if this is in the wrong spot, MODs I apologize and please move this for me.
Old May 2, 2013 | 03:52 PM
nonnieselman's Avatar
I bet it was a Vacuum leak.
Did it have a gasket on the TB and one on the TB spacer?
Old May 2, 2013 | 04:00 PM
Good point! There was no gasket between the TB and spacer. I never even considered that to be the issue. Wouldn't I have gotten the same results when I first installed the spacer though?
Old May 2, 2013 | 04:09 PM
It could have gotten worse or just was acting up at certain times.
Old May 2, 2013 | 04:30 PM
Makes sense, I suppose the symptoms could have been exaggerated with the new TB and tune. Well, hopefully this thread isn't too useless then.
Old May 2, 2013 | 04:46 PM
Drill and tap the TB spacer for a couple nozzles
Old May 2, 2013 | 04:58 PM
lol Thats the plan, I will be ordering the cam kit soon and nitrous will closely follow.
Old May 3, 2013 | 08:22 AM
D.J Vasquez's Avatar
hey ! whats up guys ! i saw this thread and i think thats what im having ! when i start it up and put it in d or r it acks like it wants to stall !! or coming to a stop light it does the samething .its is a airaid spacer !! and it was one of the first thing i put on my truck !! and its been over a year !! never thought it would be that !! and never thought to take it off !! just never crossed my mind !! but i have done everything to find out what causes that to happen !! even several quick tunes at $25 a pop !! and still nothing !! so when it get back from the tranny shop i will take it off !! but i will need to find 3 new short bolts have no ideal what i did with the original ones. is this what yall are experiencing ! thanks guys !!
Old May 3, 2013 | 05:14 PM
Sorry for the delayed response bud. Did removing the spacer help with the problems you were having?
The symptoms I was experiencing were similar to yours, but certainly not as bad. Like nonnieselman mentioned above, did you have a gasket between the throttle body and the spacer? Well let us know how it worked out. You have a nice truck by the way.
Old May 4, 2013 | 09:37 AM
hey thanks goinbrokez28 ! yes it does have a gasket between the throttle body and the spacer ,and did find the three original bolts for the throttle body !! so as soon as it gets back from the tranny shop that will be coming off !! i know i have a big cam and it does rock and shake the truck !! but its a little embarrassing when u go to start it up at a waw waws and it sounds like its starving for fuel and it wants to stall out ! but it keeps on chunking untill it clears its self out !! some times it sounds cool ?? untill u get in it !! then its wide opean throttle !!***** to the wall hold on !! love it !! guess u can tell i miss her already !!lol !! and it a beautiful saturday !! should be at the track with my boys !! will let yall know when i take it off ! and if it works ! throttle body for sail !!!! lol
jdb11386
Dec 3, 2015 09:34 PM
Aboss
Aug 11, 2015 09:05 AM
noproblems209
Aug 10, 2015 06:57 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
