Are throtle bodies worth it?
Old Apr 12, 2004 | 12:12 AM
5.3Vortec's Avatar
Banned
Default Are throtle bodies worth it?
Was thinkin about tring a bbk?
Old Apr 12, 2004 | 12:39 AM
FILE's Avatar
Save your money and port yours. It's worth about 4-5rwhp. Use those $300 on a UPD cai and use the rest for beer.
Old Apr 12, 2004 | 12:44 AM
GREGGO's Avatar
They are worth it for the right application, but really are not worth it until you get into bigger cubes and power adders. You could achieve better results IMO by getting yours ported.
Old Apr 12, 2004 | 08:49 AM
Quite a few shops will do it for you for $150.00 I was impressed on how well it came out when getting mine done.
Old Apr 12, 2004 | 09:03 AM
You really wont see much of a gain till you get up in the high HP #s.
Old Apr 12, 2004 | 10:05 AM
Lightbulb porting tb
so if mine is fly by wire and i have no throttle cable can you still port the tb or not?? get the same results
Old Apr 12, 2004 | 10:18 AM
bmbutler's Avatar
What kind of high horsepower will we need to begin taking advantage of the effect of BBK or ported throttle body?
Old Apr 12, 2004 | 12:41 PM
@ 400-450 rwhp you would bennifit from a bigger/ported TB. Under that and you engine really isnt flowing enuff to max the stock TB.
Old Apr 12, 2004 | 02:00 PM
bmbutler's Avatar
I guess the tb will be one of the next things?
Old Apr 12, 2004 | 03:02 PM
LOW2000's Avatar
If you have the fly-by-wire you could very easily over port the TB and screw your idle all up. Since they dont have the idle hole in them, they use the TB motor to control idle, with that ridge in front of the blade removed, it flows too much at idle for the computer to know what to do with.
