Are throtle bodies worth it?
They are worth it for the right application, but really are not worth it until you get into bigger cubes and power adders. You could achieve better results IMO by getting yours ported.
Originally Posted by bmbutler
What kind of high horsepower will we need to begin taking advantage of the effect of BBK or ported throttle body?
Originally Posted by Snake Eater
@ 400-450 rwhp you would bennifit from a bigger/ported TB. Under that and you engine really isnt flowing enuff to max the stock TB.
If you have the fly-by-wire you could very easily over port the TB and screw your idle all up. Since they dont have the idle hole in them, they use the TB motor to control idle, with that ridge in front of the blade removed, it flows too much at idle for the computer to know what to do with.
