Thoughts of this set up for custom tune
Old Jul 11, 2005 | 07:15 PM
1FUNZ71's Avatar
14 Second Truck Club
Default Thoughts of this set up for custom tune
91 Octane Tune
Rev Limiter 6000
1-2 Shift 5800 WOT
2-3 Shift 5800 WOT
3-4 Shift 5800 WOT
80% Torque Management Delete
Eliminate Speed limiter
Firmer Shifts
Save gas program
Tow/Haul mode adjust for maximum towing
Old Jul 11, 2005 | 07:40 PM
jerome's Avatar
save gas program AND performance? i didnt know you could do both...
maybe you can do normall is saves gas and tow/haul *** button for performance?
Old Jul 11, 2005 | 09:52 PM
one03sierra's Avatar
Formerly one92rs
Talking
91 tune
1-2 6000
2-3 5800
get the reg tune set up in normal and performance tune set up in tow haul. unless you tow all the time.
Old Jul 11, 2005 | 10:08 PM
can you get that where you normally drive(no tow/haul) and have it as gas saving, and then when you put tow haul on, its a different tune? Like even normal w/o towhaul could be for 87 oct, and then towhaul could be 93 oct?
Old Jul 11, 2005 | 10:10 PM
Formerly one92rs
Talking
yes now that i think about it. the timing tables and some others such as shift points and all can be changed.
Old Jul 12, 2005 | 12:09 AM
1FUNZ71's Avatar
Default New set uo
Regular driving
Save gas program
91 Octane Tune or 87-91 dual octane. Which ever you think is better. I run 91 mostly.
Rev Limiter 6000
1-2 Shift 5900 WOT
2-3 Shift 5800 WOT
Firmer Shifts
Tow/Haul(performance mode)
Max Tuning
Hard shifts
100% Torque Management Delete
* or whatever you think the best setup is for max performance.
When I tow I will just swap to my factory PCM.
Does this sound good?
Old Jul 12, 2005 | 12:44 AM
1FUNZ71's Avatar
to the top
Old Jul 12, 2005 | 02:25 AM
jow02327's Avatar
well if you remove you pcm i think it has to relearn
Old Jul 12, 2005 | 08:15 AM
ap2002's Avatar
is this true????
Old Jul 12, 2005 | 09:05 AM
1FUNZ71's Avatar
In some cases yes. I have heard about a few cases on here.
