Thoughts on Cams.....
Old Apr 26, 2004 | 06:38 PM
  #21
vanillagorilla's Avatar
Originally Posted by BlownChevy
This is what Matt @ comp suggested:
220/228 564/571 .115
Is that an off the shelf grind or is that custom? Does it cost any more for them to do a custom grind? That cam seems kinda lame to me for a 6.0L, especially if you're going to be doing your heads. That is a good LSA though. JMO.
Old Apr 26, 2004 | 06:47 PM
  #22
Hit Man X's Avatar
Well 220* intake isn't small but it's not huge, remeber this is in a heavy truck too so a usable RPM band would be desired. Besides I dunno if you can spin a Radix over 7000rpms on the crank...that'd be like what? 14000+ on the impeller speed?
Old Apr 26, 2004 | 06:54 PM
  #23
That's true, I never thought about what rpms the radix can turn. I guess its not like a centriffy.
Old Apr 26, 2004 | 07:01 PM
  #24
67SS509's Avatar
10 Second Truck Club
You want that wider LSA also because it moves the torque and hp a little higher in the rpms and makes the peaks a little flatter. With 6.0's and strokers and loose convertors you don't want your power at the bottom of the rpm range.
Old Apr 26, 2004 | 07:05 PM
  #25
A M112 Radix supercharger has a rated maximum speed of 16000 rpm,the revs it makes is dependent on what pulley you run and how far you are willing to chance taking it.From what I've heard 18000 rpm is the absolute safe maximum,but some of the Lightning guys take them to 19000 on a regular basis.In my oppinion there is little to be gained powerwise by taking the supercharger past 16000 rpm.
Old Apr 26, 2004 | 07:09 PM
  #26
Hit Man X's Avatar
Yeah, over that many RPMs of the blower it loses its efficiency. Kinda like pushing a tiny turbo too far...like the TD04 on my WRX. It can't hold 17psi at redline
Old Apr 26, 2004 | 08:50 PM
  #27
Banned
Brian, you told me a few weeks ago that you bought the LPE cam from my buddy to put in your truck. actually you told me it was going in your truck like the week after that when you had stock cam times. what happened to that plan?
Old Apr 27, 2004 | 12:20 AM
  #28
BlownChevy's Avatar
blownerator
25 Year Member
The deal fell through....if I had it, dont you think it would be in?
Old Apr 27, 2004 | 10:08 AM
  #29
Banned
that's why i was wondering. i didn't know if all your tranny swap time took away from the cam install or whatever. at any rate...get'er done
lukn4trbl355
Oct 21, 2015 11:19 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
Chevy305
Sep 28, 2015 09:21 PM
