Thoughts on Cams.....
I am going to install a cam in the next two weeks. Any thoughts on what to go with? I will be calling Comp tomorrow to see what they reccomend, and Magna reccomended the Lingenfelter GTII cam...something like this: 207/220 .573"/.578" 118.5.
No more thinking about it...I am going to bite the bullet this time.
I'm running a 228/234 .588/.598 115+4 with 1.75 Comp Pro Magnum rockers.The cam only has 1 degree of overlap as not to bleed off any boost.As light as your truck is I think this cam would work.The hp peak would be about 6600 rpm in a 6.0.And the cam would work with Comp 918 valvesprings.
I bet Comp will recommend their 54-424-11 (212/218, 558/563, 115). You'll be running the Radix, correct? If you have or are planning on head work, it would be a good cam. Might be wasted on stock heads, though.
Originally Posted by Flyer
Naah .. that's a little small for a 6. They recommended a 218/224 for me on the 5.3.
In general, I was told not to go over 220 for a blown application.
