Thoughts on Cams.....
Old Apr 26, 2004 | 12:08 AM
BlownChevy's Avatar
blownerator
25 Year Member
Default Thoughts on Cams.....
I am going to install a cam in the next two weeks. Any thoughts on what to go with? I will be calling Comp tomorrow to see what they reccomend, and Magna reccomended the Lingenfelter GTII cam...something like this: 207/220 .573"/.578" 118.5.
No more thinking about it...I am going to bite the bullet this time.
Old Apr 26, 2004 | 12:25 AM
I'm running a 228/234 .588/.598 115+4 with 1.75 Comp Pro Magnum rockers.The cam only has 1 degree of overlap as not to bleed off any boost.As light as your truck is I think this cam would work.The hp peak would be about 6600 rpm in a 6.0.And the cam would work with Comp 918 valvesprings.
Old Apr 26, 2004 | 12:27 AM
BlownChevy's Avatar
blownerator
25 Year Member
I have the springs installed already....Just cant make up my mind what to do with the cam
Old Apr 26, 2004 | 12:33 AM
I think Ripped 427 is running a Comp 230/236 on a 115 LS and has 0 overlap.
Old Apr 26, 2004 | 01:09 AM
Mr. Sandog's Avatar
I bet Comp will recommend their 54-424-11 (212/218, 558/563, 115). You'll be running the Radix, correct? If you have or are planning on head work, it would be a good cam. Might be wasted on stock heads, though.
Old Apr 26, 2004 | 01:11 AM
BlownChevy's Avatar
blownerator
25 Year Member
Not planning on doing the heads right now....In the future yes...but that is months away.
Old Apr 26, 2004 | 01:21 AM
Mr. Sandog's Avatar
Cool. If yer gonna do the heads, even in the future, then I bet that's what they'll recommend. Keep us posted.
Old Apr 26, 2004 | 01:52 AM
Flyer's Avatar
Naah .. that's a little small for a 6. They recommended a 218/224 for me on the 5.3.
Old Apr 26, 2004 | 02:51 AM
Mr. Sandog's Avatar
With a blower they recommended that cam? Well that would be interesting. That would mean that it depends on who you talk with there as to what advice you get, that they're not consistent.
In general, I was told not to go over 220 for a blown application.
Old Apr 26, 2004 | 05:39 AM
It's all what you want to do with your truck. They don't always recommend their off the shelf grinds though. The 212/218 seems a little small to me. But, I am definitely not a cam expert.
