thought on a 232/236 .574/.577 112
Old Nov 3, 2005 | 05:57 PM
negativeswitches's Avatar
Default thought on a 232/236 .574/.577 112
just trying to expand soem knowledge here nothing really relevant
ls1 "cars" use this cam mostly, but how would it perform in a 5.3??? i'm mostly trying to figure out how the .570's lift and the huge duration would play in the drivability factor
-Erik
Old Nov 3, 2005 | 06:24 PM
i already assume i would need a huge 3500 ish stall 4.10's which i already have jsut churious about DD ability since it has such a low lift
Old Nov 3, 2005 | 06:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Daily driveablity owuld be ****. You have to remember they have 1500-1800 pounds less to lug around. Like I said before I would go no bigger than the cam I had in my 5.3 if you want to keep it driveable IMO.
Old Nov 3, 2005 | 06:53 PM
well yes i'm not looking to buy it just trying to figure out about where it would lag and how bad
Old Nov 3, 2005 | 06:56 PM
1slow01Z71's Avatar
Bottom end owuld suck and it would start pulling hard aroun 4200-4500. Look at flyers thread he has a cam in his 5.3 that is just a tad bigger than yours and it took extensive tuning to get it running right and you have no where near what you would need to get ir running right having a mail order tune. They gain alot due to the lift of the cam and the extended duration is making your power band be way up high unless you ground the cam on like a 106-108 lsa.
Old Nov 3, 2005 | 07:00 PM
i bet that would sound freakin awsome
i see what you mean tho i think i finally made the connection lol it was so obvious
/bob and tom
-Erik
Old Nov 3, 2005 | 07:39 PM
Flyer's Avatar
If you can tune ... go for it, but not if you're going to rely on a mail order tune. If you can go to someone to tune it, that would be OK too. Don't do that with mail order tuning though.
Other than that ... I'd say go for it. I love mine, it's got a helluva lope to it and isn't bad at all on the low end. It does come alive dead on 4500, no less, no more. a phat stall would make it happier, but 3000 is more than decent with a cam that size.
Old Nov 3, 2005 | 07:43 PM
v8
17,16,15,14,13,12,11 Drvr
i have a high lift cam but the duration is alot less and a 3k stall would help me out alot, here is the specs on my cam 223 225 564 571 114 i say high lift , it is on a 5.3 as they say lol
Old Nov 3, 2005 | 07:57 PM
1slow01Z71's Avatar
Hey V8 you need to drop you a 3200 stall in there and drop 2 more tenths. My TCI 3000 that I had in my big *** truck was totally driveable oyu could get away with even bigger than that like the 3200 I said.
Old Nov 3, 2005 | 08:06 PM
OLD BULL's Avatar
Hey v8 I thought you had a PI 3200 in your truck? If not your still running a stock verter?
