thought on a 232/236 .574/.577 112
Old Nov 3, 2005 | 10:34 PM
  #21
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How much rwhp are you planning on having? SPray in your future? How do you drive? How often do you go to the track and will you be using slicks? Answer all those questions and I can basically tell you what you can "probably" get away with. I have killed two trannies so far so I know a good bit about this. Also you may want to pm 01Thunder he has killed like 11 trannies and ask him what failed on his transmissions.
Old Nov 3, 2005 | 10:49 PM
  #22
negativeswitches's Avatar
no spray, mebbie slicks or a really good sticky radial, nothing after this cam swap the 3200 stall, huge cooler, i go to the track rarely now but more after the swap i eventually want to get efi live or soemthign like it and just play with tuning and stuff, i generally drive nice old lady style and sometimes slip into led foot old lady, after i get some bigger rims i'll be auto-x style racing it a lil more
Old Nov 3, 2005 | 11:15 PM
  #23
1slow01Z71's Avatar
I owuld do the transgo hd-2 shift kit, the corvette servo, aluminum accumulator piston, and if you want for good measure sun gear shell and clutches. You should be fine with the 4 pinion planets as long as you dont up the line pressure too much and have too harsh a shifts.
Old Nov 3, 2005 | 11:38 PM
  #24
i'm not going for neck breaking shifting here
i'm afraid if i like the slicks i'll use them alot lol and go to the track more
what about the bands?
how hard is it to just replace the sunshell and clutches? i read my factory service manual it dosent seem very bad it's all laid out nicely and whatnot
how bad would it be to drive on a trans w/o TM stock internals and that stall for a week or 2 mebbie a month depends on the rebuild time it takes me to overhaul the trans in there
Old Nov 3, 2005 | 11:47 PM
  #25
1slow01Z71's Avatar
Everyones trans is different took all the tm out of mine and it killed the 3-4 clutch pack 10 miles down the road. Its russion roulette as far as thats concerned. Clutches/band needs to be replaced. Necj breakign shifts is all in the tuning and how you install the shift kit.
Old Nov 3, 2005 | 11:50 PM
  #26
i dont have any TM now but i wonder what it will do to the trans with that stall
lukn4trbl355
Oct 21, 2015 11:19 PM
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
