Those with electric fans...
Old May 24, 2004 | 10:51 AM
one03sierra's Avatar
Formerly one92rs
Talking
radio shack sells them here for a dollar.
Old May 24, 2004 | 10:53 AM
1BADHD's Avatar
Originally Posted by BigTex
I'd also double check your wiring. I haven't seen this problem before. What ingnition on wire do you have tapped for the fan controls? Do you have any other accessories wired into the same connection?
You should add a standard auto relay between the ingnition on signal wire you have tapped and the fans controller. This will isolate the ignition from the fans and should stop this problem.
I do have a relay, but its betweenthe fans and the controller. Does that matter?
Old May 24, 2004 | 10:55 AM
Formerly one92rs
Talking
i think he wants you to wire the relay to where it is the exciter. meaning to use the relay to break the ignition wire.
Old May 24, 2004 | 10:58 AM
marc_w's Avatar
Does the truck run "clean" when shut-down or does it always diesel, where it bucks, chuggs, and knocks? ("Ka-clunk Ka-clunk")
I had an old car that would do that on hot days. I'm worried your fans aren't cooling enough...
Old May 24, 2004 | 11:14 AM
1BADHD's Avatar
It has only diesels once.....out of hundred times. Temp alwas stays below the 210line on the guage.
Old May 24, 2004 | 12:03 PM
MacADaYear's Avatar
Did you use a voltometer when you hooked up your 12v ignition wire? I have had no problems like that I just made sure the power was switchable with the ignition
Old May 24, 2004 | 02:10 PM
1BADHD's Avatar
Pretty sure 02Denali and I figured it out. Its a wiring issue.
SS94S10
Jan 3, 2019 01:57 PM
drummer0415
11
Oct 24, 2015 08:16 PM
zraffz
Sep 20, 2015 08:25 PM
kalikid06
Sep 20, 2015 07:46 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
