Thinking about a LQ4
Old Aug 19, 2006 | 02:45 PM
asull79's Avatar
Default Thinking about a LQ4
I found a LQ4 longblock no intake or water pump locally for 600 bucks. It came out of a 2500 express van due to some lifter noise which I figure is the piston slap. Motor has about 60k on it what do you guys think? What would be some nice upgrades to throw on it before it goes in the truck.
Old Aug 19, 2006 | 02:51 PM
Quik's Avatar
5 year bitches!
sweet, as for what you want to toss in it would determine what your goals are
Old Aug 19, 2006 | 02:57 PM
asull79's Avatar
Probably just a cam with the stock heads nothing to fancy.
Old Aug 19, 2006 | 03:04 PM
Quik's Avatar
5 year bitches!
just remember 317s flow well but just dont have the CR that is needed for larger cams. i ran a 215,xxx mile LQ4 in our pinks car with a 224/228 581/588 114 and it ran well with stock ls1 intake. youll be happy
anarchyracing101's Avatar
be carefull with your cam choice. the lower compression of the lq4 doesnt go well with some cams.
Old Aug 20, 2006 | 02:24 PM
Colby 04's Avatar
what would be the largest cam you could effectively run with the 317's?
Old Aug 20, 2006 | 04:37 PM
Quik's Avatar
5 year bitches!
heads arent hte restrictive part, its your lack of CR
Old Aug 20, 2006 | 04:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
All depends on the setup and supporting mods. In the end it is all about how well your engine can bring in air and exhale the air. If you have a 12:1 CR engine with a 238 cam but stock intake paper filter and stock exhaust you arent going to see nearly as much of a benefit as with all the supporting mods. With that said mid 230 cam in a rcsb a fat stall, low230s high 220s in a ecsb/4wd.
Old Aug 20, 2006 | 06:25 PM
asull79's Avatar
Well the motor sold out from under me so I dont know what I want to do. Thinking about some 3.90's and a eaton posi it has a open 3.42 axle in it right now. I am not sure what I wanna do give me some ideas please
GrooveCityZ71
Aug 31, 2015 12:05 PM
darnie
Aug 10, 2015 10:25 AM
jaypowe11520
Jul 29, 2015 07:59 PM
Alco
Jul 25, 2015 01:47 PM
NuckenFuts
Jul 9, 2015 08:45 AM
