thinking about getting a cam
Old May 12, 2005 | 12:11 AM
black4x4's Avatar
Default thinking about getting a cam
I have begun to seriously think about picking a cam up sometime this summer. so far the main one i am looking at is the vinci 062. now i read the cam thread and have somequestions. the thread said 2000+ stall and vinci sight said stall is desierable so do i truely need a stall or can i skip that. also if i were to get this cam with a nelson tune lts and other boltons how would the tranny react to the new power? now for the speaks on the truck hopfully help anwser my questions 99 1/2 ton 5.3L 4.56's front and rear and i have about a 35" tall tire on it and it wieghs in the niegborhood of 6000 pounds.
Old May 12, 2005 | 12:48 AM
desTRUCKtive's Avatar
Well I have a slightly bigger cam. TR 220 with a stall. I put my cam in on Monday and the truck pulled like a ****. By thursday the tranny went BOOMMM! So I think it did not like it.
Old May 12, 2005 | 04:29 PM
mrr23's Avatar
10 Second Club
what vinci basically means is you can get away with the stock converter. but it'll be somewhat soggy taking off. the powerband is raised above where the converter will reach it's stall point (about 1100-1500). so, by using a higher than stock stall converter, you'll pass the soggy point and will get you closer to torque peak.
Old May 12, 2005 | 10:14 PM
Kano's Avatar
I gained lowend with the 062
I went from 2.2 60fts stock cam to to 2.0s 60 fts with the 062
and thats with the stock verter
Old May 12, 2005 | 10:39 PM
98TAauto's Avatar
im trying to get VHP to do a cam GP.. see down about 4-10 posts
the 44 is supposed to be a good idling/torque cam also... im probably gonna get that if the GP price is good.. its 114 like our stock cams so the idle should be pretty fair without any tuning..
112 would be a lil harder to tune, but it would sound mean
Old May 12, 2005 | 10:40 PM
02sierraz71_5.3's Avatar
sounds like a good pic on the cam might work out well with your gearing and a 2200 stall. Might also check out the old man cam or something else good for torque.
Old May 13, 2005 | 07:29 AM
black4x4's Avatar
Also does this cam pull good from 3500 to 5500. and nelson should be able to get me a tune for this cam right? plus i want the 112 lobe so it sounds alittle nicer.
Old May 13, 2005 | 07:53 AM
98TAauto's Avatar
keep in mind you would want something that pulls good form say 3000 and up... If you are getting a stall, then find out where that stall flashes and match your cam to that.. if you get a 2600 stall, figure it may stall 3000 really in a heavy truck, so pick a cam that makes power from 3000-6000.. they make cams for stock stalls also that pull from 1800+ im probably gonna just cam mine and not worry about the stall
Old May 13, 2005 | 03:40 PM
Kano's Avatar
pm me your email and Ill send you some sound clips
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
steves86ta
Jul 28, 2015 10:21 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Aboss
Jul 9, 2015 10:28 AM
