Think I found my problem with the big injectors
Old Jul 17, 2003 | 09:48 PM
  #21
parish8's Avatar
single digit dreamer
Default Re: Think I found my problem with the big injectors
it wont go up 1 for 1 but it does go past 59, seems like mine went up to 63 or so with 8psi, that is more like .5 for 1, better than nothing
Old Apr 19, 2005 | 09:13 PM
  #22
Originally Posted by XLR8NSS
If you look at the fuel pressure regulator on the driver side fuel rail there is a little vacuum line attached to it that comes from a port on the top of the intake manifold. That is the manifold pressure reference. Our fuel systems raise fuel pressure as manifold vacuum decreases or gets closer to outside pressure(0psi on your boost guage).
So at idle or cruise(low load) the vacuum is high in the manifold which causes the regulator to open the fuel return up which causes the pressure to be low. When you get on the gas the manifold goes from having a vacuum to having the same pressure as outside. If you were naturally aspirated this would show up on a boost guage as 0psi. Now when the pressure in the manifold is high(0psi) it causes the fuel pressure regulator to close the return down some which raises the fuel pressure.
The fuel pressure regulator on our trucks is very similiar in function to a FMU but, a FMU raises pressure at much more than a 1:1 rate like our regulators.
When I had my mechanical fuel pressure guage hooked up and the truck idling the pressure was 50psi. Then I just pulled that little vacuum line off the regulator for a couple seconds which causes the regulator to see regular outside pressure(0psi on a boost guage) instead of the manifold vacuum. When the reg. sees outside pressure the fuel pressure rises to 59psi.
Your fuel pressure shouldn't be staying at 50psi. Could be a bad regulator or clogged vacuum line??
with my whipple at 10lbs boost, it was suggested to me to leave that vacuum line unplugged and to cap off both ends. Good idea, bad idea? Fuel pressure sits at 60ish all the time when I do that.
Old Apr 19, 2005 | 09:27 PM
  #23
parish8's Avatar
no reason to do that. it is easier to tune with a constant presure across the injector and the regulator keeps the presure constant across the injector.
Old Apr 20, 2005 | 06:22 AM
  #24
with it unplugged, the fuel pressure is constant all the time. always 60ish. I guess I'm confused.
Old Apr 20, 2005 | 06:50 AM
  #25
parish8's Avatar
the presure is constant but the presure across the injector is not constant. the reason they make the presure regulator is to compensate for the presure or vacume in the intake.
let me give you an example. your base fuel presure is 60psi and there is no boost/vacume refrence to the reguator. you are at idle and see 18" of vacume, that vacume help pull the fuel into the motor thru the injector so you really have closer to 70psi of fuel presure across the injector.
now for boost. you still have the base presure of 60psi and you put 25psi of boost into the intake. now the fuel has to fight 25psi to get into the intake. there is just 60psi pushing it so you have to take 60-25 to get your actual presure across the injector. 35psi is all the fuel presure the injector is actualy seeing.
right there your fuel presure is varing from 35psi under boost to 70psi at idle. the port on the reguator compensates for this by pulling fuel presure at idle and adding presure under boost so what you end up with is 60psi across the inector no matter what is going on with the vacume or boost.
pittman
Jan 19, 2016 07:06 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
hartinclay
Aug 3, 2015 07:03 PM
grantpo
Jul 15, 2015 12:21 PM
