Thermostat inter-changeability (SP?)
Old May 18, 2009 | 08:50 PM
03lowriderss's Avatar
Default Thermostat inter-changeability (SP?)
OK I have my LQ9 (2005) in my truck and i just have a few more small things to do before I run it, I had nelson retune my computer for the 5.3-6.0 change w/160 degree therm.
I had a 160 degree therm on my 5.3 (2003) and I remember that I had to get a thermostat with a big built on houseing. the LQ9 has a thermostat that is removeable from the houseing.
Long story short can I use my old one piece unit on my new motor? I think that I can just want you to confirm it.
THANKS ALOT BLAKE
Old May 18, 2009 | 09:05 PM
S/C Z71's Avatar
Banned
Nope.
Old May 18, 2009 | 10:10 PM
whats the diference?
Old May 18, 2009 | 10:25 PM
budhayes3's Avatar
PT's Slowest Truck
I think that they're a different size or something...I remember that someone tried to match up a newer (04+) t-stat to and older water pump and something didn't fit right...it was a long time ago so I can't remember the details though...
*EDIT* My memory sucks so I could be totally off base here lol...
Old May 18, 2009 | 10:52 PM
does anyone know where i can find a 160 degree t-stat?
i tried autozone, the didnt have any non-stock ones?
how much should i be able to find one for?
Old May 18, 2009 | 11:03 PM
neilownz's Avatar
lingenfelter sells them and like summit, jegs, ebay etc...
Old May 18, 2009 | 11:10 PM
budhayes3's Avatar
PT's Slowest Truck
I believe that I bought mine direct from SLP IIRC...it was around $50ish at the time...
Old May 19, 2009 | 10:26 AM
JoeGibbSilverado's Avatar
i have a mr gasket one i picked up at the local parts shack, 11 bux, for an ls1
Old May 19, 2009 | 10:37 AM
budhayes3's Avatar
PT's Slowest Truck
Yours is an 05, it's the separate t-stat only, 99-03 the t-stat and housing are one piece, and considerably more expensive. Us 99-03's guys can switch to the 04+ style t-stat if we buy the separate housing and 04+ water pump...*I think*, I'm not 100% sure. As I mentioned earlier, I thought I read that the t-stats are a different size or something...
Old May 19, 2009 | 12:58 PM
so did the LS1 cars have the t stat that was removable from the housing?
