thermostat?
Old Aug 11, 2005 | 09:03 AM
TWANKYDEUCE's Avatar
Default thermostat?
I want to order a new thermostat before I order my pcm. I just dont know if I should get a 160 or 180. I'm in new orleans, so winters are mild and summers are very hot. and I also have the ls1 fans if that matters. Let me know what you guys think.
Thanks
Old Aug 11, 2005 | 09:04 AM
chevyerett's Avatar
imo, i'd go with the 160*, esp since ur in La.
btw, very clean truck
Old Aug 11, 2005 | 10:29 AM
thanks man
are there any pros and cons on both?
Old Aug 11, 2005 | 10:55 AM
oh ya, and say I go with a 180 t-stat, what temp do I want to set my e-fans on and off at?
Old Aug 11, 2005 | 10:59 AM
Start2Fabrication's Avatar
160 can be a compromise in power, but the most compelling reason I've read to use it is that it typically causes a 20 degree drop in tranny temps, which is a huge advantage in tranny longevity.
Old Aug 11, 2005 | 11:00 AM
04Denali's Avatar
Go with a 170* I just ordered one
Mark
Old Aug 11, 2005 | 12:44 PM
Okie5.3's Avatar
if you go with a 180* it will not be fully open until ~190*. these temp marketing 'ploys' i'll call them, are just the thermostats opening temps. granted, i think there may be some on the market that may open fully as advertised, but i have yet to see one. fwiw i just bought a 180* failsafe thermo for my wife's bucket and tested it in a pan of water on the stove before installing it. it too did not fully open until 192*. this was by slowly heating to get a more accurate temp of when it opened. with that said down there in party town i would go with the 160*. i have the 160* and cruising down the highway, depending on ambient temp, i stay anywhere from 176-182*. i have my fans set to come on at 185*
Old Aug 11, 2005 | 01:06 PM
Go with 160 and temps usually stay around 180.
fans on 189 fans off 180
Old Aug 11, 2005 | 06:42 PM
Question
Mark
Who sells the 170* stat?????
Jim
Old Aug 11, 2005 | 07:18 PM
04Denali's Avatar
This is where I got mine
http://www.vincihiperformance.com/LS...%20PARENT.HTML
SlvrSierra4.8
Oct 1, 2015 09:39 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Droptoplt1ta
Aug 19, 2015 07:34 PM
ou812sm
Jul 18, 2015 01:12 PM
