Tech 2 /LS1 fans??
Old Nov 20, 2004 | 02:11 PM
bodyguard6799's Avatar
Default Tech 2 /LS1 fans??
Ok, I just recently discoverd that I know someone local w/ Tech 2 that might turn on my fans once I get them mounted. I want to know exacly what needs to be done. What temps to set on/off at, the A/C, do I need a new lower tstat ?? Is there anything else that he's gonna have to do?? He's an old school mechanic so this will prob be the first time he's done this. Also once the fans are hooked up to the PCM, how do they work-- do they come on at 50% and 60% like the VSC controlled fans?? If I left anything out please let me know. THANKS!!!
Old Nov 20, 2004 | 10:05 PM
I don't think the tech 2 will do what you want it to do. You have to change the parameters in the actual pcm programming (tell it too turn on the fans). the Tech 2 wont do this by itself. If the mechanic has access to SPS programming (tech 2 extras) then you could try using the VCI option for programming. It will allow you to make changes to the factory tune. BUT you have to call somewhere and get an access key to use this feature. I'm not sure what you can and can't change using the VCI key
Gerry
Old Nov 21, 2004 | 02:38 AM
BlownChevy's Avatar
blownerator
25 Year Member
I am not 100% sure, but I dont think the Tech 2 will do any programming. I will verify this on Monday if you would like.
Old Nov 21, 2004 | 02:59 AM
Any help would be great. THANKS!!
Old Nov 21, 2004 | 03:00 AM
BlownChevy's Avatar
blownerator
25 Year Member
You betchya
Old Nov 21, 2004 | 04:20 AM
The Tech 2 can do programming, they use them to load stock programs and such, on blank/fried PCM's, but as for actual PCM manipulating, i am unsure on that one, best to ask a GM Tech. I know they can load a program, my buddy did when a hypercrap fried my 98 Z28 PCM and i had to buy a new one.
Old Nov 21, 2004 | 05:59 AM
one03sierra's Avatar
Formerly one92rs
Talking
they can reflash it with a stock program with set perimeters but cannot manipulate the tables and actions of the pcm for a prolong period.
Old Nov 21, 2004 | 08:06 AM
qwank's Avatar
even with a VCI flash it won't work. all the VCI flashes are special programs that GM has that would not be used as a default program. say you change your tire size, you can call for a VCI flash for differnt gear changes and such, as long as GM has a program for it. for instance, putting 20" wheels on a 2wd truck that came with shorter tires then the 275/55R20's they have a program that will flash the computer with the right speedo calibration for the 20's. its really hard to explain if you've never done it. but you can not do any custom tuning or programing with the tech 2
Old Nov 21, 2004 | 12:29 PM
Someone had mentioned it so I thoght I'd give it a try.
1989k1500
Nov 2, 2015 05:16 AM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
1989k1500
Sep 29, 2015 10:53 AM
