TCC not locking
Old Jul 28, 2005 | 10:38 PM
Default TCC not locking
I just put a cam in and have my idle raised so it will stay running. I havent had a chance to order my hpts and will be running the stock tune for a while. Now when I'm going down the hwy. my vertter isnt locking. I'm running 70mph at 2500rpms and I'm used to 2000. Its killing my wallet with all this gas sucking. I figure becasue of my tps not working properly becuase of the idle. My question is, If I turn the set screw back down to were it was at first and drill the hole in my tb will this fix my lock up problem? Any one else had this problem? Thanx.
Old Jul 28, 2005 | 10:52 PM
L-EATER's Avatar
11 Second Truck Club
Misfires. If you have a scanner, clear the codes (even if it doesn't show any-go ahead and hit the clear button) I am willing to bet it will lock then. Your misfire tables need adjusting to prevent this from continuing.
Old Jul 28, 2005 | 11:02 PM
Last night when we were on the way to the big city of Atmore it didnt lock up. Went into a place to eat and came out and was on the way to the shop it locked. Cleared the codes out when we got there, and locked on the way home. This moring when I went back to the shop it didnt lock and also tonight it didnt lock.
Old Jul 28, 2005 | 11:46 PM
Yep its the random misfire code that is keeping the TC from locking, just need to have it turned off with HPtuners. This is very common
Old Jul 30, 2005 | 07:11 AM
sd155racer's Avatar
Umm - misfire wont keep your TCC from locking up.
Old Jul 30, 2005 | 07:20 AM
one03sierra's Avatar
Formerly one92rs
Talking
yes sir random misfires can cause the converter to not lock up while cruising.
Old Jul 30, 2005 | 10:35 AM
budhayes3's Avatar
PT's Slowest Truck
Yep, when the PCM picks up certain faults it will go into failsafe mode and change certain perameters...tc lockup being one of them.
Old Jul 30, 2005 | 11:19 AM
Ok Thanx guys. I guess every time I go to town I will stop by the shop and clear the codes out before I head back home lol. This sux. But it sounds good though. When I get my exhaust work done and get a little air into the motor with some tunning will this cam lope like a beast or will it stay about the same?
Old Jul 30, 2005 | 02:29 PM
That cam should lope pretty well.
Old Jul 30, 2005 | 03:23 PM
It has a good lope to it now but I just want more. My exhaust sux right now, All that is there is shorties, and single flowmaster. My new is going to be a set of lts, no cats, 3" all the way into 2 ??? mufflers.
